04-21-2006 04:35 AM - edited 03-03-2019 12:28 PM
I want to create a back-to-back connection from the aux-port of a router to con-port of a switch. This seems to work for 2500 and 4000 routers. telner from the router to the switch using IP-address of the router and port 2001 connects me to the switch. However this does not seem to work for a 2600-router.
Has anything changed to the port-numbers that should be used for such a connection?
04-21-2006 04:44 AM
On the 2600 the aux port is line 65 rather than line 1 as it is on the 2500 and 4000 platforms. You need to telnet to port 2065 instead of 2001.
2611-1>sh line
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
* 0 CTY - - - - - 0 0 0/0 -
65 AUX 9600/9600 - - - - - 0 0 0/0 -
66 VTY - - - - - 0 0 0/0 -
67 VTY - - - - - 0 0 0/0 -
68 VTY - - - - - 0 0 0/0 -
69 VTY - - - - - 0 0 0/0 -
70 VTY - - - - - 0 0 0/0 -
Line(s) not in async mode -or- with no hardware support:
1-64
2611-1>
Hope this helps,
04-21-2006 07:16 AM
Thanks. That seemed to be the problemIt works fine now.
04-21-2006 07:20 AM
Klaas,
Please rate the posting if it was useful.
