connecting C3750 switch to a C3560
Hi I would be grateful for any help with this question. I have tried for hours to find an answer on the website with no joy.
I need to connect a C3750 to a C3560 switch, both located in the same rack. I believe I can’t use the StackWise cable as its not supported on the C3560 however, I would like to know if I can use a Cisco SFP interconnect cable to do the job? My concern is that the C3750 will not recognise the SFP module as valid (as I can’t see it on the supported list) and will disable the port or produce errors.
Would I be better off using two 1000base-T SFP modules and a piece of CAT5e instead or is there a better solution out there (without changing the switches or connecting at 100mbs)?
Any advice or pointers in the right direction on the website would be gratefully received
Dean
2 ACCEPTED SOLUTIONS
Re: connecting C3750 switch to a C3560
You cannot use the SFP interconnect to connect a 3750 to a 3560 for the reason you mentioned. You can use 1000baseT SFPs or 1000 base SX SFPs and use fiber with LC connectors to connect the 2 switches.
Dean,
Are your gbics Cisco gbics or third party ones ? Usually third party gbics when inserted into the gbic slot, shuts down the port. You should be fine with the GLC-SX or GLC-T gbics, and interconnect the switches(i think GLC-Ts are cheaper).
Dean,
Thanks to both of you for your advice. I will go with 2 x SFP 1000base-T and Cat5e Solution using Cisco branded items and consign the Interconnect cable to history.
Your quick response to my plea for help is appreciated
Dean
129
