06-11-2007 02:39 AM - edited 03-03-2019 05:22 PM
Hello friends,
I have two offices to be connected over 3xT1 lines, I have placed router at both end, both routers are able to ping each other, but LANs are not connecting. my configuration is :
Current configuration : 1241 bytes
version 12.4
service password-encryption
hostname SL
boot-start-marker
boot-end-marker
no logging console
enable secret 5 XXXXXXXXXXXXXXXXXXXXXXX
aaa new-model
aaa session-id common
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
multilink virtual-template 1
username amar password 7 XXXXXXXXXXXXXXXX
interface FastEthernet0/0
ip address 192.168.3.1 255.255.0.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
bandwidth 2048
no ip address
encapsulation ppp
pulse-time 3
ppp multilink
interface Serial0/1/0
bandwidth 2048
no ip address
encapsulation ppp
pulse-time 3
ppp multilink
interface Serial0/1/1
bandwidth 2048
no ip address
encapsulation ppp
pulse-time 3
ppp multilink
interface Virtual-Template1
ip unnumbered FastEthernet0/0
ppp multilink
ip classless
side B
ip add is : 192.168.2.1/16
06-11-2007 02:47 AM
you are missing routing, either static or dynamic. Please pick a configuration example from CCO and apply.
06-11-2007 02:49 AM
Is it possible to readdress you ip addressing scheme?
If you can then you can change the local lan block to 192.168.3.0/16 or /24 even on one end and 192.168.2.0/16 or /24 at the other end..
Once you are done with this do change the ip address on the wan interfaces..
Instead of creating virtual template interface try creating interface multilink and bundle the physical links onto it..
Once you are done with the bundling and assigning the interfaces to it assign 10.1.1.1 on Side A and 10.1.1.2 on Side B..
Do make sure that you are assigning /30 as your subnet mask to the ip addressing scheme..
You need to add a reverse route for the respective lan blocks on both the ends so that you can have lan to lan reachability...
regds
06-11-2007 05:20 AM
Amrendra
You have not given enough information for us to be sure what the issue is. You have given us the config of one router and 1 IP address from the other router. At a minimum we need to know what is the addressing of the LAN on the other router.
As was pointed out in a previous post there does not appear to be any static routes or any dynamic routing protocol in the config that you posted. Without either static routes or dynamic routing protocol the router will have no knowledge of how to reach the LAN of the other router, producing the symptoms that you describe.
At this point I would make a guess that the second router may also be using 192.168.0.0/16 on its LAN. If so this would be a problem. If router 1 believes that 192.168.0.0/16 is local then it will never send any traffic over the serial attempting to reach 192.168.0.0/16 on the other router.
Rick
06-11-2007 05:42 AM
Hi Rick,
Excellent answer, I rated a '5'. What a pity that in the scale of someone else, you risk a maximum rating of '2' :(
06-11-2007 07:15 AM
as quoted earlier change the subnet masks of both the ckts to /24
192.168.1.0/24
192.168.2.0/24
Then run configure a routing protocol like EIGRP on both the routers.
router eigrp 1
network 192.168.1.0
network 192.168.2.0
re-distribute static
HTH - rate as useful posts
06-12-2007 12:44 AM
Hello Anand,
It really worked, but one more problem I am facing is , this is network of 1.0/24 is able to communicate to 2.0/24.
But I have 10.0/24, or 40.0/24 as LAN their on other sides, how can they ping to 2.0/24 or 1.0/24. ?
Thanks.
06-12-2007 01:31 AM
How are they being routed ? what is the conenction between the gateways 192.168.10.1 & 192.168.40.1 & the two routers for which you have pasted configs ?
Also note - That in future if you want more thant 255 hosts, you will have to change the subnet mask for the 192.168.2.0 & 192.168.1.0 network.
If you feel they will not scale it is ok else change it to say 192.168.1.0 / 255.255.240.0 & 192.168.2.0 / 255.255.240.0 right away
06-12-2007 02:28 AM
Hello Amerandra Kumar,
what you can do is, juz configure the 192.168.10.1/24 ip address on fas 0/1 interface on Router A & on Router B fas 0/1 configure the ip address as 192.168.20.1/24, & give the gateway to the PC, your problem will be solved.
