Community Member
Connecting to two vlans over vpn (1721)
I have two vlans configured on a 1721 router, Vlan 1 and Vlan 20. Remote computers are issued addresses from Vlan1 range and they  can rdp to computers in Vlan1. Why can't they ping or rdp to machines in Vlan 20? Any help will be appreciated.
Office#sh conf
Using 3788 out of 29688 bytes
version 12.4
hostname Office
boot-start-marker
boot-end-marker
enable secret xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
aaa new-model
aaa authentication ppp default local
aaa authorization network default if-authenticated
aaa session-id common
clock timezone GMT 1
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no ip dhcp use vrf connected
ip dhcp excluded-address xxxxxxxxxxxxxxxxxxx
ip dhcp pool INTERNAL1
   import all
   network xxxxxxxxxxxxxxxxxxxxxxxxx
   default-router xxxxxxxxxxxxxxxxxxxxx
   domain-name mathelize.com
   dns-server xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
   lease infinite
ip dhcp pool 172-Network
   import all
   network xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
   default-router xxxxxxxxxxxxxxxxxxxxxxxx
   lease infinite
p cef
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
vpdn enable
vpdn-group mygroup
vpdn-group myvpn
Default PPTP VPDN group
accept-dialin
  protocol pptp
  virtual-template 1
crypto pki trustpoint TP-self-signed-213732786
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-213732786
revocation-check none
rsakeypair TP-self-signed-213732786
crypto pki certificate chain TP-self-signed-213732786
certificate self-signed 01 nvram:IOS-Self-Sig#3636.cer
spanning-tree uplinkfast
spanning-tree backbonefast
interface FastEthernet0
description Outside Network
ip address dhcp
ip access-group 110 in
ip nat outside
ip virtual-reassembly
no ip route-cache cef
no ip route-cache
no ip mroute-cache
speed auto
full-duplex
no cdp enable
interface FastEthernet1
description CONNECTION TO 172 NETWORK
switchport access vlan 20
vlan-id dot1q 1
  exit-vlan-config
vlan-id dot1q 20
  exit-vlan-config
interface FastEthernet2
vlan-id dot1q 20
  exit-vlan-config
spanning-tree portfast
interface FastEthernet3
vlan-id dot1q 20
  exit-vlan-config
interface FastEthernet4
description Private Network
vlan-id dot1q 1
  exit-vlan-config
interface Virtual-Template1
ip unnumbered FastEthernet0
peer default ip address pool DIAL-IN
ppp encrypt mppe auto required
ppp authentication ms-chap ms-chap-v2
interface Vlan1
ip address xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
ip nat inside
hold-queue 100 out
interface Vlan20
ip nat inside
router ospf 1
log-adjacency-changes
router ospf 1
passive-interface FastEthernet0
network xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx area 0
ip local pool DIAL-IN xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
ip forward-protocol nd
ip route xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
ip http authentication local
ip http secure-server
ip nat inside source list 101 interface FastEthernet0 overload
access-list 101 permit ip xxxxxxxxxxxxxxxxxx any
access-list 101 permit ip xxxxxxxxxxxxxxxxx any
access-list 110 permit ip any any
control-plane
alias exec s sh ip int brief
alias exec sipr sh ip route
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
exec-timeout 0 0
password 7 00000000
logging synchronous
transport input telnet ssh
Office#
505
