Connection 2 Router using VWIC-T1 2MFT card
I have been trying to connect two router together for a lab both has a VWIC-T1 2MFT card i can't get it to work. can someone help?
Re: Connection 2 Router using VWIC-T1 2MFT card
Are these back to back routers? What cable/pinout are you trying to use? Do you have configs that you can post.
Please note that you will need a special T-1 crossover cable and a standard patch cable will not work.
http://www.cisco.com/en/US/docs/wireless/cards/t1e1vwic/1941cvwic/c1941wic.html#wp1070542
HTH,
Mark
what do youe mean by back to back? from one router to the other if that yes.
i was using a UTP Xover cable. i don't have any config yet.
First I would say that you will need to purchase/make a cable for your lab.
T1 cross-over cable pinout:
* pin 1 to 4
* pin 2 to 5
* pin 4 to 1
* pin 5 to 2
HTH,
Mark
393
