01-11-2010 12:17 AM - edited 03-04-2019 07:10 AM
The ISP give me a range of public IP space
Network: 46.28.13.240 /28
Gateway: 46.28.13.254
Useable: 46.28.13.241-.253
Mask: 255.255.255.240
The ISP interface is RJ45 Ethernet.
On my side is a Cisco 2811 router with only 2 Ethernet interfaces and advance-security software.
I try to make a switch port on the router but that is not porssible.
How do you make a connection between the ISP and the router ?
Solved! Go to Solution.
01-13-2010 07:09 AM
As the information provided to you by your ISP is this:
Here you can use any one of the ip addresses from the Useable Range and assign the same to the WAN Interface that is pointing towards the ISP Side.
So, for example if you are using Fastethernet 0/0 as the WAN Interface, then hook it as following:
Router(config)#int FastEthernet0/0
Router(config-if)#ip address 46.28.13.241 255.255.255.240
Router(config-if)#ip nat outside
Router(config-if)#no shut
Make sure, you add in the default route to the next hop that is the Gateway in this case:
Here is the command to do the same:
Router(config)#ip route 0.0.0.0 0.0.0.0 46.28.13.254
Assign, the LAN configurations on the other side of the FastEtherenet port which is your LAN side:
So , assuming that you have FastEthernet0/1 which is the LAN interface, try the following config:
Router(config)#int FastEthernet0/1
Router(config-if)#ip address x.x.x.x y.y.y.y ( Private Ip address )
Router(config-if)#ip nat inside
Then you have to make sure that we are overloading the NAT on the WAN Interface:
Thus, we would have to globally call the NAT statement using this command:
Router(config)#ip nat inside source list 1 interface FastEthernet0/0 overload
Here, access-list 1 would specify the interesting traffic originating from the LAN.
Here is a related document on NAT:
Configuring NAT for IP Address Conservation
http://www.cisco.com/en/US/docs/ios/12_4t/ip_addr/configuration/guide/htaddrs.html
Also, the rest of the usable Ip address can be used for dedicated machines like Servers which can use one to one static mapping.
Hope that helps!
Rishika
01-11-2010 03:29 AM
You can configure your setup one port for LAN and one port for ISP end and configure NATTING in router for internet routing for internal users.
Just configure a normal port by entering into the interface and configure ip address and no shut .
Hope that helps
Ganesh.H
01-13-2010 07:09 AM
Hope that helps!
Rishika
01-13-2010 10:45 PM
Yes
This soltuin fixed the problem..
Thankx
