Connection limiting on ASA
raimj
I have ASA 5510. I am letting my outside customers on FTP on my server (port range 49152 65535)
Is it possible to limit the number of connections from one particular source address (My customer).
Manny
John Blakley
Manny,
You should be able to lock your customer down in your ftp server. I don't believe you're going to be able to do this in the ASA.
HTH,
John
HTH, John *** Please rate all useful posts ***
I was looking at config guide. Don't you think this will do the trick..
ASA(config-pmap-c)# set connection {[conn-max n] [embryonic-conn-max n] [per-client-embryonic-max n]
I looked at that option, and it's really hard to say if that's outbound or inbound, or if it can be either. I've never used that option. It's a possibility that you could create an acl, match that acl in a class map, apply the class map to a policy map, and then set the connection limit that would only affect the host that you're wanting to affect.
HTH,
John
