connectivity issue on Cisco 2811
Hi all,
I'm having an issue with my Cisco 2811. The Internal FastEthernet0/1 interface is showing Link up but Protocol down. I have tried various combinations with the speed and duplex on the port and having no luck.
The port connects to our Fortigate 110c router. Your assistance with this is appreciated.
Hall of Fame Super Bronze
Router-to-Router needs a crossover cable.
Edison
Re: connectivity issue on Cisco 2811
cabling between devices was already there and was working. The only change was to the port speed and duplex on the port. I changed this port to Auto Auto by mistake - should have been interface 0/0. I have reverted settings back but port still won't come up.
You can do 'shut' followed by 'no shut' on the Cisco side, this will reset the port state.
Not sure if they are similar commands in the other router.
II will give that a try but assuming that those commands would be equivalent of restarting router which I've done many times already?
Both routers? Try swapping the cables..
238
