cons to aux connection
Hi All,
I have a router at a remote site and want to configure a new router remotly. For that i want to connect a roll over cable from old router aux port to new router console port.
How do i access the new router after telneting to the old router. Is the any initial configuration to be done prior to connect to the new rourer.
Appreciate your help.
1 REPLY
Gold
Re: cons to aux connection
On old router
line aux 0
transport input all
exit
and now see the line number of aux port:
show line
it will be number X (1 or 5 or whatever)
then find any live ip (fe. inside IP) address on the router and do reverse telnet like this
telnet 2000+x
if x is 5 then 2000+5=2005
so it's telnet 2005
M.
Hope that helps rate if it does
101
