Controller T1 configurations
Greetings,
I will be replacing my 3660 router(all serial ports) with the 3800 router(controller T1 ports). Can bandwidth, ip address, and ecapsulation be configured on the controller? Thank you.
Gold
Re: Controller T1 configurations
It will depend which t1 cards you get.
Things like wic-t1-v2 are configured under the serial interface. vwic-mfc-t1 are configure both with a controller and the serial interface.
Basically on the cards that allow you to run fractional t1 you will need to configure the controller to get it to create the serial interfaces.
Tdrais,
Thanks for your input, I was able to configure my serial ports.
104
