03-21-2006 04:57 AM - edited 03-03-2019 12:07 PM
Dear All,
I am converting a Cat 6509 from CatOS to IOS, i've found a nice pdf "http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801350b8.shtml", but i have a problem; i can't find the appropriate image on the Cisco website.
When i search i found either one of 2 --> MWAM or CCM which i think that both are not what i need.
Can anybody advice how to get the appropriate one.
Thanks in advance.
Solved! Go to Solution.
03-21-2006 05:12 AM
Do you have a CCO login.
If yes, then you can dowload it from here :
http://www.cisco.com/kobayashi/sw-center/lan/cat6000-sup-ios.html
HTH,Please rate if it does.
-amit singh
03-21-2006 05:12 AM
-amit singh
