Converting Interfaces from ATM to MLFR
Equip: 3660, NM-2W, VWIC-2MFT-T1(x2), AIM-ATM. Question: Will there be any issues reconfiguring this hardware for MLFR? There's currently a 'mode atm aim 0' command on the T1 controllers which I presume needs to come out, but will doing so allow those ports to be grouped for MLFR without any other issues? TIA for any tips!
Craig
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Converting Interfaces from ATM to MLFR
No CCS or CAS configuration for your data application. You define the timeslots used with the channel-group command in contraller configuration mode.
Hope this helps, if so please rate post using the scrollbox below.
Absolutely, once you negate the commands for ATM, the serial ports will return available for whatever configuration you like.
Hope this helps, please rate posts using the scrollbox below!
Thanks! I see that in addition to 'ATM' there are mode options for CCS & CAS - are one of these necessary or will the default (whatever that might be) suffice? Appreciate the help!
113
