Community Member
correct IOS for controller command
I am trying to configure my 2 2821 routers in my training lab and I cant find the controller command required to setup the t1 lines, I have a 2600 with a single t1 to run my house and I want to put use the new bonded circuit my intention is to use the vwic-2mft-t1dir card I have in slots 1 and 3 to do so. both come up as unknown cards.
sh version :
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9_IVS-M), Version 12.4(25b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 12-Aug-09 11:53 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T6, RELEASE SOFTWARE (fc1)
HCM-c28001 uptime is 10 minutes
System image file is "usbflash1:c2800nm-image-2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2821 (revision 53.50) with 249856K/12288K bytes of memory.
Processor board ID FTX1016A4K8
2 Gigabit Ethernet interfaces
2 Virtual Private Network (VPN) Modules
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
1983213K bytes of USB Flash usbflash1 (Read/Write)
sh diag:
Slot 0:
.C2821 Motherboard with 2GE and integrated VPN Port adapter, 2 ports
.Port adapter is analyzed
.Port adapter insertion time 00:01:31 ago
.Onboard VPN..: v2.2.0
.EEPROM contents at hardware discovery:
.PCB Serial Number        : FOC101116LG
.Hardware Revision        : 1.0
.Top Assy. Part Number    : 800-26921-01
.Board Revision           : A0
.Deviation Number         : 0
.Fab Version              : 03
.RMA Test History         : 00
.RMA Number               : 0-0-0-0
.RMA History              : 00
.Processor type           : 87
.Hardware date code       : 20060317
.Chassis Serial Number    : FTX1016A4K8
.Chassis MAC Address      : 0017.5a67.53b0
.MAC Address block size   : 32
.CLEI Code                : CNMJ6P0BRB
.Product (FRU) Number     : CISCO2821
.Part Number              : 73-8853-03
.Version Identifier       : V02
.EEPROM format version 4
.EEPROM contents (hex):
.  0x00: 04 FF C1 8B 46 4F 43 31 30 31 31 31 36 4C 47 40
.  0x10: 03 E8 41 01 00 C0 46 03 20 00 69 29 01 42 41 30
.  0x20: 88 00 00 00 00 02 03 03 00 81 00 00 00 00 04 00
.  0x30: 09 87 83 01 32 18 9D C2 8B 46 54 58 31 30 31 36
.  0x40: 41 34 4B 38 C3 06 00 17 5A 67 53 B0 43 00 20 C6
.  0x50: 8A 43 4E 4D 4A 36 50 30 42 52 42 CB 8F 43 49 53
.  0x60: 43 4F 32 38 32 31 20 20 20 20 20 20 82 49 22 95
.  0x70: 03 89 56 30 32 20 D9 02 40 C1 FF FF FF FF FF FF
.WIC Slot 1:
.T1 Drop&Insert (2 port) WAN daughter card with relays
.WIC module not supported/disabled in this slot
.Hardware revision 1.0         .Board revision A0
.Serial number     30720439  .Part number    800-18412-03
.FRU Part Number
.Test history      0x0         .RMA number     00-00-00
.Connector type    Wan Module
.EEPROM format version 1
.  0x20: 01 3E 01 00 01 D4 C1 B7 50 47 EC 03 00 00 00 00
.  0x30: 50 00 00 00 03 07 10 01 FF FF FF FF FF FF FF FF
.WIC Slot 3:
.Serial number     32348647  .Part number    800-18412-03
.FRU Part Number
.  0x20: 01 3E 01 00 01 ED 99 E7 50 47 EC 03 00 00 00 00
.  0x30: 50 00 00 00 04 06 02 01 FF FF FF FF FF FF FF FF
.AIM Module in slot: 0
.PCB Serial Number        : FOC11253DDP
.Hardware Revision        : 1.1
.Top Assy. Part Number    : 800-24799-03
.Fab Version              : 03
.RMA History              : 00
.CLEI Code                : CNUCAG6AAA
.Product (FRU) Number     : AIM-VPN/EPII-PLUS
.  0x00: 04 FF C1 8B 46 4F 43 31 31 32 35 33 44 44 50 40
.  0x10: 01 4B 41 01 01 C0 46 03 20 00 60 DF 03 42 41 30
.  0x30: C6 8A 43 4E 55 43 41 47 36 41 41 41 CB 91 41 49
.  0x40: 4D 2D 56 50 4E 2F 45 50 49 49 2D 50 4C 55 53 89
.  0x50: 56 30 32 20 FF FF FF FF FF FF FF FF FF FF FF FF
.  0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
.  0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
worth mentioning both units are new to me off ebay in the last 2 weeks, I purchased 2 so if needed I could swap parts. they came with the t1 and vpn cards already in them, same with the os version.
Re: correct IOS for controller command
The VWIC-2MFT-T1-DIR card doesn't look like it will work in the 2800 platform. All my searches are showing you need to put this in the MWR 1900 Mobile Wireless Router.
http://www.cisco.com/en/US/docs/wireless/cards/t1e1vwic/1941cvwic/c1941wic.html
http://www.cisco.com/en/US/docs/wireless/mwr_1900/1.0/hardware_install/guide/1900ovr.html#wp1025952
jerry
Community Member
That Agrees from with my findings too, I was hoping that I was missing something
403
