cosmetic bug? (interface errors)
enriquebs
HI all,
Here is some output information about this interface which connect a P router to a PE router by a direct fiber link, I posted this issue days ago, as the errors didn't fall into any "error category" we changed gbit and fiber in order to discart any phisical problem, but the interface is acting in the same way...
Maybe a cosmetic bug?
P01#sh int gi2/1
GigabitEthernet2/1 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 0015.c674.5b80 (bia 0015.c674.5b80)
Description: "LAN-2"
Internet address is 10.9.128.185/29
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is SX
input flow-control is off, output flow-control is off
Clock mode is auto
Last input 00:00:00, output 00:00:03, output hang never
Last clearing of "show interface" counters 3w0d
Queueing strategy: fifo
Packet Drop strategy: random early detection (DWRED)
Output queue: 0/40 (size/max)
5 minute input rate 184000 bits/sec, 163 packets/sec
5 minute output rate 227000 bits/sec, 76 packets/sec
L2 Switched: ucast: 322327 pkt, 22582413 bytes - mcast: 619541 pkt, 54936288 bytes
L3 in Switched: ucast: 73474516 pkt, 22669324805 bytes - mcast: 61470 pkt, 5901016 bytes mcast
L3 out Switched: ucast: 49581920 pkt, 16821811640 bytes mcast: 562004 pkt, 52764082 bytes
74599811 packets input, 22771306818 bytes, 0 no buffer
Received 803377 broadcasts (58516 IP multicast)
8496526 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
50933386 packets output, 16754829095 bytes, 0 underruns
enriquebs
more information...
P01# sh counters interface gigabitEthernet 2/1
64 bit counters:
0. rxHCTotalPkts = 159983390
1. txHCTotalPkts = 102939063
2. rxHCUnicastPkts = 152405408
3. txHCUnicastPkts = 90309308
4. rxHCMulticastPkts = 7577920
5. txHCMulticastPkts = 12629718
6. rxHCBroadcastPkts = 62
7. txHCBroadcastPkts = 37
8. rxHCOctets = 37118699428
9. txHCOctets = 24854326260
10. rxTxHCPkts64Octets = 16453592
11. rxTxHCPkts65to127Octets = 184827857
12. rxTxHCPkts128to255Octets = 17613013
13. rxTxHCPkts256to511Octets = 17974038
14. rxTxHCpkts512to1023Octets = 2816545
15. rxTxHCpkts1024to1518Octets = 10302069
16. txHCTrunkFrames = 0
17. rxHCTrunkFrames = 0
18. rxHCDropEvents = 0
32 bit counters:
0. rxCRCAlignErrors = 0
1. rxUndersizedPkts = 0
2. rxOversizedPkts = 10660497
3. rxFragmentPkts = 0
4. rxJabbers = 0
5. txCollisions = 0
6. ifInErrors = 10660497
7. ifOutErrors = 0
8. ifInDiscards = 0
9. ifInUnknownProtos = 0
10. ifOutDiscards = 0
11. txDelayExceededDiscards = 0
12. txCRC = 0
13. linkChange = 0
14. wrongEncapFrames = 0
All Port Counters
1. InPackets = 159981630
2. InOctets = 37118504588
3. InUcastPkts = 152403652
4. InMcastPkts = 7577916
5. InBcastPkts = 62
6. OutPackets = 102938057
7. OutOctets = 24853376134
8. OutUcastPkts = 90308306
9. OutMcastPkts = 12629714
10. OutBcastPkts = 37
11. AlignErr = 0
12. FCSErr = 1
13. XmitErr = 0
14. RcvErr = 10660497
15. UnderSize = 0
16. SingleCol = 0
17. MultiCol = 0
18. LateCol = 0
19. ExcessiveCol = 0
20. CarrierSense = 0
21. Runts = 0
22. Giants = 0
23. InDiscards = 0
24. OutDiscards = 0
25. InErrors = 10660497
26. OutErrors = 0
27. TrunkFramesTx = 0
28. TrunkFramesRx = 0
29. WrongEncap = 0
30. Broadcast_suppression_discards = 0
31. Multicast_suppression_discards = 0
32. Unicast_suppression_discards = 0
33. rxTxHCPkts64Octets = 16453586
34. rxTxHCPkts65to127Octets = 184825904
35. rxTxHCPkts128to255Octets = 17612921
36. rxTxHCPkts256to511Octets = 17973966
37. rxTxHCpkts512to1023Octets = 2816521
38. rxTxHCpkts1024to1518Octets = 10301986
39. DropEvents = 0
40. CRCAlignErrors = 0
41. UndersizedPkts = 0
42. OversizedPkts = 10660497
