covad PPPoFR. no default GW. why?
according to the docs this config below should work but i don't seem to have a default route installed. whats worse is that i cannot add a static route to the virtual-access interface that gets built after the passwords are accepted.
Leon
interface FastEthernet0/0.3
encapsulation dot1Q 3
ip address 21.13.12.177 255.255.255.248
interface Serial0/0:1
no ip address
encapsulation frame-relay IETF
interface Serial0/0:1.1 point-to-point
frame-relay interface-dlci 16 ppp Virtual-Template1
interface Virtual-Template1
ip address negotiated
ppp chap hostname xxxx
ppp chap password 0 yyyy
ppp ipcp dns request
ppp ipcp route default
ppp ipcp address accept
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: covad PPPoFR. no default GW. why?
I'm referring to:
ip local pool default 10.10.10.10 10.10.10.11
About which you have not reported.
You have
consequently configuring default route is unnecessary.
i wish it was that easy. I think covad is not returning a default GW when cisco makes a PPP request for it.
Gateway of last resort is not set
21.13.12.0/29 is subnetted, 1 subnets
C 21.13.12.176 is directly connected, FastEthernet0/0.3
20.86.15.0/32 is subnetted, 1 subnets
C 20.86.15.119 is directly connected, Virtual-Access1
Covad does not need to return anything, the default route is installed once IPCP is open (interface up).
If it doesn't work, may be a bug, just configure default pointing to virtual-template.
Windsor1760(config)#ip route 0.0.0.0 0.0.0.0 virtual-?
Virtual-PPP Virtual-TokenRing
Virtual-Template is not an option for the ip-route statement. the defaut-route is not automatically installed and i cannot manually point it to the Virtual Access interface that is added.
Leon
Not sure, perhaps is virtual-ppp, or just the serial subif.
virtual-ppp can't be added since it doesn't exist and adding the serial sub-int is pointless because the sub-int has "no ip address" and ultimately that route doesn't make it to the route table.
A serial interface doesn't need to have an predetermined IP address to be used in a static route. Or, you can use 20.86.15.119 instead that is the address of remote router.
the IP assigned on the virtual interface is my WAN ip. i don't believe it is the remote IP.
from what i understand, the PPP interface is like a tunnel and i need to send the data down that tunnel. right now the serial interface has no ip and accordingly i cannot add a static route to something that is not IP enabled.
when i add an IP address such as 1.1.1.1 to the serial interface then make the serial interface the default route, packets go out the interface but never make it to the internet.
I need to route down the "Virtual-Access 1" interface but i can't. what am i missing?
Leon
Have you edited the output, right ?
Can you take "debug ppp neg" with "term mon" ? Another /32 route for the peer, should be installed for you to use as default. You can try to use 209.86.152.119 anyway.
i tried to delete the 3rd digit from the IPs to change keep things private but its not working anyway...
here is the debug.
i think the default route is not being added to the PPP profile by my provider. unfortunately Earthlink wants me to use the netopia they sent instead of my 1760 so i can't really complain to them.
on the other hand, i should be able to add a default route to point to the PPP interface but i don't know how to do so.
Leon
Go ahead and use 209.86.152.119 let us know if it works.
Remote doesn't come with an own address and seems even willing to accept one. That is the reason why ppp ipcp default route didn't work in first place.
There is no such thing as passing a default route in PPP, it's purely a local decision.
Windsor1760(config)#ip route 0.0.0.0 0.0.0.0 209.86.152.119
%Invalid next hop address (it's this router)
i'm sure a default gateway is to be assigned the same way the WAN address is assigned. with dial-up PPP you get your IP as well as the default gateway. why shouldn't this be any different.
"ppp ipcp route default" this command should ask for the GW ip i'm sure.
Leon
Dialup PPP is different from router logic, the thing here is that the remote does not communicate an address. Can be an oversight by covad.
The command ppp ipcp route default does not ask for anything, compare traces with and without if you don't believe.
Try this:
interface virtual-template 1
peer default ip address 10.10.10.10
That may lead the ppp ipcp route default to start working once the remote IP address is known.
Windsor1760(config)#int virtual-Tem 1
Windsor1760(config-if)#peer default ip address ?
dhcp Use DHCP proxy client mechanism to allocate a peer IP address
dhcp-pool Use local DHCP pools to allocate a peer IP address
pool Use IP pool mechanism to allocate a peer IP address
Windsor1760(config-if)#peer default ip address 10.10.10.10
% Invalid input detected at '^' marker.
Right, an explicit address is not allowed on an virtual interface, to prevent multiple assigments.
Go ahead and configure a pool
and use pool in peer default ip address
All this in the hope of finally providing the remote with a valid address.
the command is entered but it won't stick in the running config.
Windsor1760(config-if)#peer default ip address pool
Windsor1760#sh run | s Tem
ppp chap hostname ms23808095
ppp chap password 0 uzasgu8f
ppp pap sent-username ms23808095 password 0 uzasgu8f
Windsor1760#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Windsor1760(config-if)#no ppp ipcp route default
Windsor1760(config-if)#do sh run | s Tem
Have you configured the pool ?
Can you take the ppp trace again ?
It may not stick due to using the default pool.
For sure you're meeting a lot of undue difficulties.
Also very strange is how the router keeps sending CONFreq before finally accepting the reply more than one minute later.
But, let's see if you resolve the connectivity problem first.
Your configuration looks good. Can you please try the following configuration ?
no ip address
ppp multilink
ppp multilink group 1
interface Multilink1
ppp multilink
If you still dont see the default route, add a static default ponting to Multilink1 interface
HTH,
Rakesh
not that i haven't tried this already but this was indeed a valiant attempt. the problem is that Multilink1 does NOT get assigned an IP. "Virtual-Access 1" is created with the IP and so that's where i need to route my data to. when i point the default GW to multilink 1 the result is the same as when i pointed the default GW to Serial 0/0:1.1. In that situation, the static route never made it to the route table because the interface does NOT have an IP.
i need to be able to set the default gw to "Virtual-Access 1"
PS i also tried using a route-map to force all traffic to "virtual-Template 1" and that didn't help
Leon
Covad1760(config)#ip route 0.0.0.0 0.0.0.0 multilink 1
Covad1760(config)#
Covad1760#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
65.0.0.0/28 is subnetted, 1 subnets
S 65.15.36.64 [1/0] via 172.16.0.1
172.16.0.0/24 is subnetted, 1 subnets
C 172.16.0.0 is directly connected, FastEthernet0/0.1
216.135.129.0/29 is subnetted, 1 subnets
C 216.135.129.176 is directly connected, FastEthernet0/0.3
209.86.152.0/32 is subnetted, 1 subnets
C 209.86.152.119 is directly connected, Virtual-Access1
Covad1760#sh ip int brief
FastEthernet0/0 unassigned YES NVRAM up up
FastEthernet0/0.1 172.16.0.5 YES manual up up
FastEthernet0/0.2 unassigned YES NVRAM deleted down
FastEthernet0/0.3 216.135.129.177 YES manual up up
Serial0/0:1 unassigned YES manual up up
Serial0/0:1.1 unassigned YES unset up up
NVI0 unassigned NO unset up up
Multilink1 unassigned YES manual down down
Virtual-Access1 209.86.152.119 YES IPCP up up
Virtual-Template1 unassigned YES manual down down
Virtual-Access2 unassigned YES unset down down
Covad1760#
ppp multilink
no ip address
ppp multilink
Please remove "ip address negotiated" from interface Virtual-Template1.
-Rakesh
Virtual-Access1 unassigned YES TFTP up up
Covad1760#
Have you bounced your serial interface to re-initiate PPP negotiation ? If so, its time to call the TAC I guess.
-Rakesh
yes i bounce the controller.
the whole reason i'm here is bacause my 1760 is EOL and so TAC won't renew the service contract.
Cisco refuses to take my money.
Leon
Can you please trun on "debug ppp negotiation" ? Do a shut/no shut on ser 0/0 and post the output . Also,please post sh ip int brief.
-Rakesh
there is a debug with my original config attached to my post at "May 24, 2009, 12:54pm PST". here is the debug with multilink and without ip negotiation.
Leon
Have you tried with pool configured ?
May 24 15:52:00.070: Vi1 IPCP: I CONFREQ [REQsent] id 1 len 10
May 24 15:52:00.074: Vi1 IPCP: Address 0.0.0.0 (0x030600000000)
May 24 15:52:00.074: Vi1 IPCP: Cannot satisfy pool request
May 24 15:52:00.074: Vi1 IPCP: Neither side knows remote address
see my "May 24, 2009, 7:01pm PST" post. the command is entered but it does not stay in the config when i do show run it is not there.
how can i get TAC to help? they won't take my money because my 1760 is EOL but this is clearly an IOS issue. I'm sure a brand new 1801 would fail. if i plug the Covad Netopia in, it works just fine.
I'm referring to:
340
