CPU doubles going from 12.4(4)T1 to 12.4(11)T1
We have a 7206VXR NPE-G1 which was running 12.4(4)T1 happily at around 25% CPU utilization. With the latest Cisco security patch alerts - we upgraded the IOS to 12.4(11)T1 and CPU immediately doubled. No config change.
It runs with C7200-ADVIPSERVICESK9-M. "sho proc cpu sorted" shows nothing higher than 1.5%.
It has a few GigaE interfaces and some FEs and pkt rates are as follows:
30 second input rate 92974000 bits/sec, 17418 packets/sec
30 second output rate 88059000 bits/sec, 17063 packets/sec
30 second input rate 102690000 bits/sec, 18859 packets/sec
30 second output rate 95586000 bits/sec, 18797 packets/sec
30 second input rate 1548000 bits/sec, 663 packets/sec
30 second output rate 6152000 bits/sec, 739 packets/sec
30 second input rate 2575000 bits/sec, 1025 packets/sec
30 second output rate 9037000 bits/sec, 1243 packets/sec
Many of the interfaces run NBAR (protocol discovery) as well as to rate-limit P2P. But all that ran fine pre-upgrade. Now CPU runs at 75%.
Ideas?
Thanks!
Re: CPU doubles going from 12.4(4)T1 to 12.4(11)T1
Can you execute "show proc cpu" and check which process/service is getting too much attention from CPU?
None:
CPU utilization for five seconds: 67%/63%; one minute: 72%; five minutes: 71%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
71 501000 1496866 334 1.31% 1.29% 1.32% 0 IP Input
230 25716 1439400 17 0.98% 0.98% 0.98% 0 traffic_shape
231 139288 409570 340 0.32% 0.32% 0.32% 0 SDP Process
54 6212 3933515 1 0.32% 0.34% 0.32% 0 T3E3 EC IPC POLL
44 52228 20075 2601 0.24% 0.24% 0.24% 0 Per-Second Jobs
229 2196 37896 57 0.08% 0.03% 0.02% 0 PIM Process
94 16 566 28 0.08% 0.00% 0.00% 0 TCP Timer
227 748 20051 37 0.08% 0.01% 0.00% 0 IGMP Input
232 2536 618642 4 0.08% 0.08% 0.08% 0 PPP manager
10 0 331 0 0.00% 0.00% 0.00% 0 IPC Dynamic Cach
9 0 2 0 0.00% 0.00% 0.00% 0 ATM VC Auto Crea
12 44 19823 2 0.00% 0.00% 0.00% 0 IPC Periodic Tim
11 0 1 0 0.00% 0.00% 0.00% 0 IPC Zone Manager
13 24 19823 1 0.00% 0.00% 0.00% 0 IPC Deferred Por
15 0 1 0 0.00% 0.00% 0.00% 0 IPC BackPressure
16 304 19823 15 0.00% 0.00% 0.00% 0 EnvMon
17 0 1 0 0.00% 0.00% 0.00% 0 OIR Handler
14 0 1 0 0.00% 0.00% 0.00% 0 IPC Seat Manager
19 1296 5841 221 0.00% 0.00% 0.00% 0 ARP Input
20 800 20690 38 0.00% 0.00% 0.00% 0 ARP Background
Use the troubleshooting recommendation in this link and let us know the outcome http://www.cisco.com/warp/public/63/highcpu.html#symptons
That link was of little use. The CPU doesn't indicate any problem. No individual process over 2%.
What is interesting is "show inter switching", but Output Intepreter didn't yield any insights. See attachment.
173
