04-24-2012 11:29 PM - edited 03-04-2019 04:08 PM
Hi ,
In Cisco 7206 VXR (NPE-G2) router , the cpu utilization is at an 80-90% always , but none of the process is consuming not more than 1%.In the show stacks output we are observing network interface interrupt is called very frequently. so what does network interface interrupt is about.
Logs for the reference:
show proce cpu sorted
CPU utilization for five seconds: 88%/88%; one minute: 89%; five minutes: 89%
PID Runtime(uS) Invoked uSecs 5Sec 1Min 5Min TTY Process
1 0 72 0 0.00% 0.00% 0.00% 0 Chunk Manager
2 20020000 17159 1166 0.00% 0.02% 0.01% 0 Load Meter
3 0 1 0 0.00% 0.00% 0.00% 0 cpf_process_tpQ
4 0 1 0 0.00% 0.00% 0.00% 0 EDDRI_MAIN
5 471180000 27537 17110 0.00% 0.04% 0.03% 0 Check heaps
6 8000 21 380 0.00% 0.00% 0.00% 0 Pool Manager
7 0 1 0 0.00% 0.00% 0.00% 0 DiscardQ Backgro
8 0 2 0 0.00% 0.00% 0.00% 0 Timers
9 0 2 0 0.00% 0.00% 0.00% 0 ATM AutoVC Perio
10 0 2 0 0.00% 0.00% 0.00% 0 ATM VC Auto Crea
----------output truncated------------------------------------
ABC#sh stacks
Minimum process stacks:
Free/Size Name
11068/12000 MRIB IPv4 Init Process
11480/12000 MRIB IPv6 Init Process
5552/6000 Inspect Init Msg
59324/60000 script background loader
58924/60000 EEM Auto Registration Proc
5324/6000 CDP Protocol
5548/6000 SASL MAIN
2528/3000 allegro libretto init
11068/12000 Router Init
3336/12000 Init
4360/6000 DIB error message
5508/6000 BGP Accepter
5040/6000 BGP Open
5340/6000 RADIUS INITCONFIG
34148/36000 TCP Command
5492/6000 URPF stats
2548/3000 Rom Random Update Process
5240/6000 Delayed Reload
6016/12000 Virtual Exec
Interrupt level stacks:
Level Called Unused/Size Name
1 2845320824 7344/9000 Network interfaces
2 0 9000/9000 DMA level Interrupt
3 321 8780/9000 PA Management Int Handler
4 2904 8892/9000 Console Uart
5 0 9000/9000 OIR/Error Interrupt
7 21453943 9000/9000 4ms Timer Interrupt
Palani
04-25-2012 10:13 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
It likely is packet forwarding in the "fast path"; which doesn't show as a process. If you're pushing around a gig or so of aggregate bandwidth through the 7200, this would be expected.
04-26-2012 11:21 PM
Hi joseph,
But the traffic is less than 60-70mbps on gig interface always . CEF is enabled. a Cisco 7200 router is capable of handling that much traffic.
Palani
04-27-2012 12:56 AM
Hello Palani,
follow the guidelines of the following document to further troubleshoot your issue
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00801c2af0.shtml
in some cases the traffic volume is not high as you noted, but packets are processed in a slow path.
Hope to help
Giuseppe
04-27-2012 02:20 AM
Disclaimer
Posting
Agreed, a -G2 should easily handle only 60-70 Mbps of traffic in "fast path".
As Giuseppe noted, "slow path" could consume much more CPU at a much lower transfer rate, but then you would expect to see the CPU being consumed by IP Input process.
When I looked at your original post, one oddity that did catch my eye, your 5 second CPU usage was 88%/88%. Usually, at best, as such high usage, you see interrupt usage within 1 or 3 percent of total CPU, not exactly the same, as some CPU is consumed by background processes. Your posted process does show some of this, but numbers like .02% and .04%. So, I'm wonder whether this might be some display bug.
04-27-2012 03:11 AM
Hi ,
As per my assumption, the cpu utilization is due to interrupts. which we can see in the output of show stacks where the network interface interrupt is called very offen and called in high numbers i searched a lot about netowork interface field not much help. Suspecting on the bug side upgraded the ios to latest release and done the reload too..
Logs:
ABC# sh stacks
Free/Size Name
5548/6000 SASL MAIN
3336/12000 Init
5040/6000 BGP Open
1 3215499403 7344/9000 Network interfaces
3 327 8780/9000 PA Management Int Handler
4 2914 8892/9000 Console Uart
7 21981998 9000/9000 4ms Timer Interrupt
ABC# sh stacks
Free/Size Name
5548/6000 SASL MAIN
3336/12000 Init
5040/6000 BGP Open
1 3215732279 7344/9000 Network interfaces
7 21982331 9000/9000 4ms Timer Interrupt
Palani
04-27-2012 03:45 AM
Disclaimer
Posting
What's prior and reloaded IOS versions? Same CPU stats?
Suggest you open a TAC case.
04-27-2012 04:26 AM
Hi Doherty,
Yes the cpu stats remain the same( 80-90%) after the ugrade.
c7200p-adventerprisek9-mz.150-1.M8.bin
c7200p-adventerprisek9-mz.124-24.T7.bin
c7200p-adventerprisek9-mz.124-24.T2.bin
Palani
04-27-2012 07:07 AM
Disclaimer
Posting
If the total traffic passing through your -G2 is only 60-70 Mb(its)ps (not one interface, i.e. sum all ingress or all egress traffic across all interfaces), then, again, suggest you open a TAC case.
04-28-2012 02:05 AM
Try to undebug all , may be it is the issue
04-28-2012 09:00 AM
Hi ,
Thanks all for the valuable suggestions. will check with tac.
Palani
05-01-2013 12:44 AM
Hi Palani,
Did you manage to solve your problem? I am facing the same issue with high interrupts 90%-100% running voip on 7206vxr NPE-G2 at about 90Mbps. The pps was only 170k which is way below the published 2mil pps.
Any suggestions on this is very much appreciated.
Kit
04-16-2016 09:56 AM
Hi Experts, same situation, same issue.
Do you have found a solution?
C7206VXR with NPE-G2 with hig cpu interrupts running 100Mbps of VoIP traffic.
I noticed also a strange 4ms Timer Interrupt in show stacks.
router#sh stacks
1 1297587812 6596/9000 Network interfaces
3 8 8772/9000 PA Management Int Handler
4 3309 8892/9000 Console Uart
7 31070716 9000/9000 4ms Timer Interrupt
Can you explain me what is this process?
Regards.
