crossover between 3550's failing
I noticed my port lights are not illuminated on two 3550's connected together at port 12 via a xover cable (tried a new cable same problem), ...any ideas?
Thx.
Re: crossover between 3550's failing
I have the following setup for xover port 12;
No Switchport
No IP address
shutdown
duplex full
Silver
The interface is shut. did u try unshut the interface ....... ?
Regds
How do you restart an interface (3550 ios 12.1 (22))?
it would be ideally no shutdown command which will enable the interface.
hope u are aware the procedure on how to get onto the interface level mode where you keyin this command..
regds
regds
135
