01-03-2008 05:19 AM - edited 03-03-2019 08:07 PM
Anyone have any idea or know the documentation for what this error means?
%CRYPTO-6-IKMP_MODE_FAILURE: Processing of Informational mode failed with peer at remote_ip_address
Dandy
01-03-2008 05:52 AM
Look at http://www.cisco.com/en/US/docs/ios/12_3/sem1/system/messages/emgcpad.html
I hope this helps.
Best regards.
Massimiliano.
01-03-2008 08:20 AM
Thanks for the link.
It says "contact the remote peer". I hope she's a lady so I can ask her for a date :)
Update:
Well, I turn ON debugging and now I see more info about what could be the problem. After fixing it, the VPN is up now without error. However everybody is sleeping now, we will test it tomorrow and if there's more problem I will follow up this post.
Dandy
01-03-2008 08:48 AM
The remote peer is not unlikely to be (operated by) a lady. But watch out! Although the recommended action was what you quoted, the explanation for the message suggests your issue was due to failure of negotiation with the remote peer :-)
Kind Regards,
Maria
