CSS 11503: Loadbalancing on http header fields with dynamic values.
We have front end portals and webservices behind them. When a user loggs in to the portal a call is made from the portal to the backend webservices.
If we have a header field "Username" on the call from the portal to the webservices and the value is the users username, is it then possible to configure CSS11503 to loadbalance each call so that each returning call with that username will end up on the same node.
A sort of "Sticky User".
The reason for this is that we are caching the users data heavily and we do not want calls from a single user to be scattered over all nodes.
Thanks in advance!
Best Regards
Per Arneng
1 REPLY
Silver
Re: CSS 11503: Loadbalancing on http header fields with dynamic
You can configure the CSS to inspect incoming content requests for HTTP header-field information. The CSS then directs the requests to the servers that are designed to handle the type of content that is requested.Refer URL
http://www.cisco.com/en/US/products/hw/contnetw/ps789/products_configuration_example09186a0080222630.shtml#configs
149
