Community Member
CSS 11503 redirect regular expression as parameter
we are using LoadBalancers 11503 to let users go to internal webservices (via a portal). For this reason we have several services and contentrules defined.
Now we want to implement a rule that allows a user to be redirected to a specific webserverpage depending on what his initial url is.
should be redirected to something like
This is very easy if we are talking of 1 or 2 applications to register for, but we already have 37 applications, which we all want to make accessible via the same principle: take part <applic1> from initial url and post it in the redirect-url as paramter. With this, <applic1> can be re-used by a whole bunch of values.
I know in Unix this can be done with "positional" params in Regular Expressions (RE):
http.*register-(.*) will result in a $1 having the value that stands between the brackets, which would redirect to$1
Is something like this possible in CSS 11500, and if so, how?
Thanks in advance.
Jan Sneyers
Re: CSS 11503 redirect regular expression as parameter
check out the following link on Configuring Redirects on the CSS 11000 , hope this helps :
Community Member
Hi, sorry for the late answer, but I had some vacation.
I went through this document, and I already knew a part of it (redirection in Contentrules).
I tried to solve this topic by the second option (service with domain-redirect), but the problem is that I need to pass a domain larger than 64 bytes (71 to be precise): I need to take it through a portal (first http.... and then add the real internal server, second http...), with a result as
So, not a very good solution.
I'm really looking for something that can be done on the CSS itself, but seems impossible to find.
Any help still very much appreciated.
Jan Sneyers.
