Community Member
Dampening an interface
How can I dampen an EIGRP interface if interface flaps for 5 times in 15 second. ?. I searched the net for this topic, I couldn't find clear cut answer. Thanks
Re: Dampening an interface
I feel ip even dampening will be able to do justice for your requirement ..
do refer this link for more info on how to configure the same..
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080457c1d.html#wp1048359
do check out for the supported interfaces ...
regds
Community Member
Thanks Kumar for your input. The link didn't help much, as no one of the 4-parameters configured in interface dampen command take into consideration the numbers of interface flaps over specific period of time.
Community Member
time to do some maths then, using the penalty for each flap and setting the half life and the threshold to dampen.
Community Member
Appreciate your input. I couldn't find a link shows how to assign a penalty for each flap. It would be great help if you are aware of any. Thank you
the penalty for a flap is 1000 and can not be configured. In fact the interface dampening is very similar to route flap dampening in BGP. Have a look at document RIPE-229 for the latter to get also some hints on how to "do the maths".
Martin
Community Member
Thanks Martin. Your answer is what I was looking for. Thank you
Community Member
Under which item did you find the "how to do the maths" ?
Luis
4298
