06-09-2009 02:06 PM - edited 03-04-2019 05:03 AM
i have spent some time trying to get DDNS to work with freedns.afraid.org.
they do not use the name:pw authentication the others use, they use a SHA key at the end of a string.
http://freedns.afraid.org/dynamic/update.php?U2lnOWswTVRTTUl-and-so-on
you can past this string into a browser and it works perfectly, when the router sends it i get a the html source for the splash screen.
06-09-2009 02:50 PM
In other words ?
Conclusion ?
06-11-2009 08:07 AM
i guess that was a little ambiguous - it doesn't work. I've been through the iad_ddns doc backwards and forwards.
ip ddns update method not4u
HTTP
add http://freedns.afraid.org/dynamic/update.php?U2lnOWswTVRTTUlBQUhTbmVvRTozNjI5NjQ1
interval maximum 0 0 5 0
interval minimum 0 0 5 0
Response:
001132: .Jun 11 16:07:26: DYNDNSUPD: Adding DNS mapping for not4u.ignorelist.com <=> 172.25.243.165
001133: .Jun 11 16:07:26: HTTPDNS: Update add called for not4u.ignorelist.com <=> 172.25.243.165
001134: .Jun 11 16:07:26: HTTPDNSUPD: Session ID = 0x43
001135: .Jun 11 16:07:26: HTTPDNSUPD: URL = 's0t0pe@freedns.afraid.org/dynamic/update.php?U2lnOWswTVRTTUlBQUhTbmVvRTozNjI5NjQ1')">http://eugeneb:s0t0pe@freedns.afraid.org/dynamic/update.php?U2lnOWswTVRTTUlBQUhTbmVvRTozNjI5NjQ1'
001136: .Jun 11 16:07:26: HTTPDNSUPD: Sending request
001137: .Jun 11 16:07:26: HTTPDNSUPD: Response for update not4u.ignorelist.com <=> 172.25.243.165
001138: .Jun 11 16:07:26: HTTPDNSUPD: DATA START
001141: .Jun 11 16:07:26: HTTPDNSUPD: Response for update not4u.ignorelist.com <=> 172.25.243.165
001142: .Jun 11 16:07:26: HTTPDNSUPD: DATA START
001143: .Jun 11 16:07:26: HTTPDNSUPD: DATA END, Status is Response data recieved, successfully
001144: .Jun 11 16:07:26: HTTPDNSUPD: Call returned SUCCESS, update of not4u.ignorelist.com <=> 172.25.243.165 succeeded
001145: .Jun 11 16:07:26: DYNDNSUPD: Another update completed (outstanding=0, total=0)
001146: .Jun 11 16:07:26: HTTPDNSUPD: Clearing all session 67 info
06-11-2009 09:56 AM
If you think it should work, but it doesn't, you should contact the TAC, so they can either suggest a working config, or file a bug as necessary.
06-11-2009 03:20 PM
was trying the community first -
thanx
06-17-2009 02:39 AM
I experience the same problem, I see the HTTP request to freedns.afraid.org is sent with a HTTP Host header set to the IP address of freedns.afraid.org, this is causing the trouble. The response is easily reproduced using wget:
wget -q -O - --headers "Host: freedns.afraid.org" 'http://freedns.afraid.org/dynamic/update.php?XYZ...'
works correctly, while
wget -q -O - --header "Host: 67.19.72.205" 'http://freedns.afraid.org/dynamic/update.php?XYZ...'
does not work and reproduces the response mentioned above.
Excuse my dump question: Who is the TAC?
06-17-2009 07:17 AM
TAC is the Technical support organization for Cisco, if you don't have a contract it costs you to open a support ticket,
you can find TAC under support from the main page.
06-18-2009 12:59 PM
after trying many variables - i gave up and moved to dyndns.com
this is working well.
08-06-2009 10:18 PM
dear freind
i was trying to configure in cisco 877/K9 but it dont work can post your config Dyndns ?, will be appreciable
Taher
08-07-2009 08:16 AM
no problem - here you go, enjoy
HTTP
add s3cr3tk3y@members.dyndns.org/nic/update?system=dyndns&hostname')">http://eugeneb:s3cr3tk3y@members.dyndns.org/nic/update?system=dyndns&hostname=
interval maximum 1 0 0 0
interface FastEthernet0/1
description
ip dhcp client client-id ascii not4me
ip dhcp client hostname not4me
ip ddns update not4me host members.dyndns.org
ip address dhcp
ip access-group Wan-Deny in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip nat outside
no ip virtual-reassembly
duplex auto
speed auto
no cdp enable
crypto map Stealth
ip access-list extended Wan-Deny
permit udp any eq bootps any eq bootpc
permit icmp any any
permit tcp any any established
permit ahp any any
permit esp any any
permit icmp any any echo-reply
permit icmp any any time-exceeded
permit icmp any any unreachable
permit udp any eq domain any
permit tcp any any eq 22
permit udp any any eq isakmp
permit udp any any eq non500-isakmp
permit tcp any any eq 4500
permit tcp any any eq 10000
permit udp any any eq ntp
permit tcp any any eq 5223
permit udp any any range 3478 3479
permit udp any any eq 28960
permit tcp any any eq 8000
11-17-2010 02:58 AM
