Debug commands for ISDN
Jul 4 2006 19:31:31.739 AEST: ISDN BR0/3/0 EVENT: UserIdle: callid 0x8007 received ISDN_CALL (0x0)
*Jul 4 2006 19:31:31.739 AEST: ISDN BR0/3/0 EVENT: process_bri_call: call id 0x8007, called_number XXXXXXXXXXX, Guid BR0/3/0speed 64, call type DATA, calling_number none
*Jul 4 2006 19:31:31.739 AEST: ISDN BR0/3/0 EVENT: handle_l2d_srq_mail: Activating Layer 1
*Jul 4 2006 19:31:31.739 AEST: ISDN BR0/3/0 EVENT: isdn_sw_cstate: State = 4, Old State = 4
*Jul 4 2006 19:31:31.743 AEST: ASSERTION FAILED: file "../chips/gt96k/gt96k_timer.c", line 771
*Jul 4 2006 19:31:39.743 AEST: ISDN BR0/3/0 EVENT: isdn_layer1_failure: Layer 1 not active even after T3 delay
*Jul 4 2006 19:31:39.743 AEST: ISDN BR0/3/0 EVENT: isdn_sw_cstate: State = 0, Old State = 4
*Jul 4 2006 19:31:39.747 AEST: ISDN BR0/3/0 Q931: L3_ShutDown: Shutting down ISDN Layer 3
*Jul 4 2006 19:31:39.747 AEST: ISDN BR0/3/0 EVENT: process_rxstate: ces/callid 1/0x8007 calltype 1 HOST_DISCONNECT_ACK
*Jul 4 2006 19:31:39.747 AEST: ISDN BR0/3/0 **ERROR**: host_disconnect_ack: Unfound B-channel on Disconnect_Ack call id 0x8007
*Jul 4 2006 19:31:39.747 AEST: ISDN BR0/3/0 EVENT: service_queue_from_physical_layer: Recvd L1 prim 3 state is 3
The above shown debug output is obtained giving debug ISDN events. I am configuringthis remote router and i could't able to get the ISDN link up. I persume the cable is not connected to the ISDN WIC card.
I am also repeatedly getting the following message for every few minits.
*Jul 4 2006 19:31:20.739 AEST: ASSERTION FAILED: file "../chips/gt96k/gt96k_timer.c", line 771....
My IOS version is 12.3(8r)T8
If some one can figure out what might be the cause of the problem, it will be a great help.
Rajesh
Silver
Re: Debug commands for ISDN
for your message, maybe a bug? I don't know.
Normally "Unfound B-channel" is a L1 problem.
Try to check with
"show isdn status"
"debug isdn q921"
Please let me know
Andrea
Thanks Andrea
Since i cannot access the router physically and its sitting on an remote end, i am not sure whether the ISDN cable is connected with the routers ISDN wic. Have organized a guy to check it. Soon will be letting you to know.
Once again... does any one have any idea about the apperance of the following message.
*Jul 4 2006 10:53:25.183 AEST: ASSERTION FAILED: file "../chips/gt96k/gt96k_timer.c", line 771....
This messages appears every few minutes.
Rajesh
Silver
please try "show isdn status", and check the output.
If you see "Layer 1 Status: DEACTIVATED", maybe you have a problem with cable (not connected or wrong) or ISDN wic.
Your BRI interface is U or S/T?
for the ASSERTION FAILED message, move the card to a slot other than slot0. That's a known bug: CSCsc40230
Hope this helps
Andrea
Hall of Fame Super Silver
There have been several posts in the forums about this error message. See this link for a post from Georg which discusses the bug:
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=WAN%2C%20Routing%20and%20Switching&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1dda3133
I believe that it makes the same suggestion that Andrea does which is to move the card to a different slot.
Rick
637
