Webcast-Catalyst9k
Deny 15 IP's with ACL
I need to deny 15 IP's on my network.
I'm using the following IP addressing 10.246.32.22/22 and the IP's I need to deny are 10.246.32.230 to 10.246.32.245.
Is there any option on the ACL's to deny this range of 15 IP's or I have to deny one IP per line?
I apreciate your comments!!
1 ACCEPTED SOLUTION
Silver
Re: Deny 15 IP's with ACL
Hi there,
There's no option to enter a pure range.. you'll have to find bitboundaries and write your ACL.. I have done this for you here:
access-list 100 deny ip 10.246.32.230 0.0.0.1 any
access-list 100 deny ip 10.246.32.232 0.0.0.7 any
access-list 100 deny ip 10.246.32.240 0.0.0.3 any
access-list 100 deny ip 10.246.32.244 0.0.0.1 any
At least there less than 15 entries.. :)
Did it help?
Silver
Hi there,
Did it help?
Thank you Johansens!!!
It' helped a lot!!!
Sorry fellows,
what about this full-range access-list:
access-list 100 deny ip 10.246.32.230 0.0.0.15 any ?
Thank you for consideration.
hjmacholl
Purple
In order to match the given range using a wildcard mask of 0.0.0.15, the network address specified on the ACL has to be a multiple of 16. If you enter the ACL as you have posted above into a router, it will change it to:
access-list 100 deny ip 10.246.32.224 0.0.0.15 any
The important thing here is to use the right bit boundary when configuring ACLs. With a mask of 0.0.0.15, the last 4 bits of your network address have to be zero. When converted to binary, 230 is 11100110 whereas 224 in binary is 11100000 (the last 4 bits are zero).
Therfore, the answer to your question is that the ACl you have specified will not work.
Hope that helps... pls rate helpful posts.
Paresh
Silver
Hi there,
Sorry, but it won't work, because it's not on a proper bitboundary:
10.246.32.230 = 00001010.11110110.00100000.11100110
00.000.00.015 = 00000000.00000000.00000000.00001111
There should never be active bits in the "wildcard-space" when specifying a subnet.
Let's take a look at the 'offending' range:
10.246.32.231 = 00001010.11110110.00100000.11100111
10.246.32.232 = 00001010.11110110.00100000.11101000
10.246.32.233 = 00001010.11110110.00100000.11101001
10.246.32.234 = 00001010.11110110.00100000.11101010
10.246.32.235 = 00001010.11110110.00100000.11101011
10.246.32.236 = 00001010.11110110.00100000.11101100
10.246.32.237 = 00001010.11110110.00100000.11101101
10.246.32.238 = 00001010.11110110.00100000.11101110
10.246.32.239 = 00001010.11110110.00100000.11101111
10.246.32.240 = 00001010.11110110.00100000.11110000
10.246.32.241 = 00001010.11110110.00100000.11110001
10.246.32.242 = 00001010.11110110.00100000.11110010
10.246.32.243 = 00001010.11110110.00100000.11110011
10.246.32.244 = 00001010.11110110.00100000.11110100
10.246.32.245 = 00001010.11110110.00100000.11110101
What you need to check for is the maximum bits you can use which DOESN'T change starting from the left travelling to the right in the bitpatterns.
From the list above, you would think the following could be used:
10.246.32.224 = 00001010.11110110.00100000.11100000
Here we are mask out the bits which could vary:
00.000.00.031 = 00000000.00000000.00000000.00011111
But this encompasses more than the range you wanted to use. With thise subnet and wildcard, you'll select from .224 up to and including .255 which would clearly be too much.
Then we'll need to break the range down to smaller ranges. Let's also look at the values above and after the interesting range:
10.246.32.225 = 00001010.11110110.00100000.11100001
10.246.32.226 = 00001010.11110110.00100000.11100010
10.246.32.227 = 00001010.11110110.00100000.11100011
10.246.32.228 = 00001010.11110110.00100000.11100100
10.246.32.229 = 00001010.11110110.00100000.11100101
10.246.32.246 = 00001010.11110110.00100000.11110110
10.246.32.247 = 00001010.11110110.00100000.11110111
10.246.32.248 = 00001010.11110110.00100000.11111000
10.246.32.249 = 00001010.11110110.00100000.11111001
10.246.32.250 = 00001010.11110110.00100000.11111010
Now you can see where you'll have to break the patterns down:
at 1110011x, giving a wildcard of 00000001 for the first two,
at 11101xxx, giving a wildcard of 00000111 for the next eight,
at 111100xx, giving a wildcard of 00000011 for the next four,
at 1111010x, giving a wildcard of 00000001 for the last two.
So, then you have the subnets and wildcards given:
11100110 = .230, 00000001 = .1
11101000 = .232, 00000111 = .7
11110000 = .240, 00000011 = .3
11110100 = .244, 00000001 = .1
Did it help? If so, please rate it.
Hallo johansens,
your explanation was very understandable to me.
Thank you for help!
hjmacholl
128
