08-08-2006 11:53 PM - edited 03-03-2019 01:36 PM
hi
how can i deny a big from the world to my router,i want that small ping like for exemple 32 byte will be avalible , but big ping will be deny.
thanks
08-09-2006 12:15 AM
I think you should check policy-based routing.
There are some possibilities to match packets after its size (match length _min _max). I never used this feature myself but on paper it looks promising... :-)
Check this document for example
//Mikhail Galiulin
08-09-2006 12:22 AM
i don't want to deny addresses i wany to deny a big ping to my interface.
08-09-2006 12:34 AM
This is exactly what I recommend:
use MATCH LENGTH command in route map
//Mikhail Galiulin
08-09-2006 12:43 AM
i understand you
but what if want to move a big packet like 1400
and ping i want to move maximum 32?
08-09-2006 12:52 AM
I guess you need to combine two "match" statements in the same route map - one will be based on extended access-list and choose only ping trafic and another one will check the packet size.
//Mikhail Galiulin
08-09-2006 02:46 AM
i try that and it's not success
08-09-2006 04:00 AM
Here is the solution that works (just tried it in my lab on 2 17XX routers):
class-map match-all large_ping
match packet length min 1000
match protocol icmp
policy-map tst
class large_ping
drop
interface FastEthernet0
ip address 192.168.112.252 255.255.255.0
service-policy input tst
Here is the result:
EMBOR1FRA#ping 192.168.112.252 size 1000
Sending 5, 1000-byte ICMP Echos to 192.168.112.252, timeout is 2 seconds:
Success rate is 0 percent (0/5)
EMBOR1VPNA#ping 192.168.112.252 size 999
Sending 5, 999-byte ICMP Echos to 192.168.112.252, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/5/8 ms
EMBOR1VPNA#
//Mikhail Galiulin
