Webcast-Catalyst9k
Description to static routes
hello
i am a new network administrator in my office, and i wonder if there is a way to add description's to static routes?
thanks in advance
Shahar, Max
Re: Description to static routes
you can define a description using name keyword attached to the ip route statement..
do refer this link for more info..
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124tcr/tiad_r/adressht.htm#wp1136518
regds
thank you.
Hi Shahar,
Use the "name" keyword at the end of the route and if the description which you want to give is more than one word then use "" between the statement.
Something like this
Switch(config)#ip route 0.0.0.0 0.0.0.0 x.x.x.x name "DEFAULT ROUTE"
Ankur
*Please rate all helpfull post
1501
