Webcast-Catalyst9k
Determining a Frame Relay PVC real speed
Is out there an IOS command for determining the actual speed of a Frame Relay PVC on a Cisco router?
Thanks.
1 REPLY
Re: Determining a Frame Relay PVC real speed
show frame-relay qos-autosense
shows PVCs parameters.
But I'm not sure whether it will work if your service provider uses equipment of manufacturers other than Cisco on its end or disabled this feature.
//Mikhail Galiulin
104
