DHCP across WAN
naive.naive
Need my branches client to get dhcp address from the HQ DHCP server. How do i configure that?
Branches switch
Branches router
HQ router (connected to VLAN 200)
HQ Core switch
HQ DHCP server (connected to VLAN 100)
Other than ip helper-address on the branches LAN interface, what else is needed??
"ip helper-address x.x.x.x" is all you need on the branch office router interface. The statement converts the broadcast into a directed request to the target specified.
If you have multiple VLAN's in the regional offices, each requiring DHCP services, you'll need to add "ip helper-address" statements to each of the VLAN sub-interfaces on the router.
Of course, you'll need to configure the DHCP server appropriately. It'll know which DHCP lease to serve the IP addresses from.
You can also use multiple "ip helper-address" statements too, for multiple DHCP servers. However, you'll need to carve up the DHCP lease pools, so that the leases don't clash.
One problem we've experienced - PC's may not be able to talk across the LAN segment if the WAN link dies, so you may want to have a think about how you're going to serve out IP addresses during WAN failures.
nothing need to configure on the core switch or the HQ router?
No, as Rebecca said you need to add config to remote office routers and create DHCP scopes on your DHCP server.
The core switch and HQ router do not need any additional config.
Jon
