DHCP client lease on 2801
I'm trying to configure the DHCP client lease time on a 2801 router and can't seem to find the correct command. I've tried searching the Cisco site and found a command that looked like it would do the job (ip dhcp client lease x x x), but when I tried inputting that into the router it didn't recognize the command.
In looking through the router's commands I've found ip dhcp-client limit lease per x which seems to be an interface command and doesn't sound like what I'm trying to do.
Can anyone help?
Thanks!
Re: DHCP client lease on 2801
Is the 2801 a DHCP server or client ? If its a server, under each pool, you have a command called Lease
We have the router acting as a DHCP server. Thanks for the reply!! I'll start looking under those settings.
207
