11-25-2011 05:56 AM - edited 03-05-2019 06:46 AM
Hello All,
I have an existing vlan 333 that I use for a data network and pull dhcp requests from a MS Server, works perfectly.
I have created a new voice vlan 334 with an ip-helper pointing to my dhcp server. I have setup the new scope on the server, but for what ever reason
my phones cannot receive an IP. If I use vlan 333 for the phones they work fine. Any help would be appreciated,what am I missing from my config ?
version 12.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname-SWITCH
enable secret 5 $1$2MHS$CV7j3THosU.cCEsr67wiz/
username itmiss privilege 15 secret 5 $1$frKc$sLXZ6HUu9hqM8IV8cjjqe1
aaa new-model
aaa authentication login default group tacacs+ local
aaa authorization exec default group tacacs+ local
aaa accounting update newinfo
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
aaa session-id common
switch 1 provision ws-c3750-48p
switch 2 provision ws-c3750-48p
system mtu routing 1500
vtp domain jevco
vtp mode transparent
ip subnet-zero
no ip source-route
ip routing
no ip gratuitous-arps
ip tcp synwait-time 10
no ip domain-lookup
ip domain-name jevco.local
ip ssh time-out 60
ip ssh version 2
mls qos map cos-dscp 0 8 16 26 32 46 48 56
mls qos srr-queue input bandwidth 90 10
mls qos srr-queue input threshold 1 8 16
mls qos srr-queue input threshold 2 34 66
mls qos srr-queue input buffers 67 33
mls qos srr-queue input cos-map queue 1 threshold 2 1
mls qos srr-queue input cos-map queue 1 threshold 3 0
mls qos srr-queue input cos-map queue 2 threshold 1 2
mls qos srr-queue input cos-map queue 2 threshold 2 4 6 7
mls qos srr-queue input cos-map queue 2 threshold 3 3 5
mls qos srr-queue input dscp-map queue 1 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue input dscp-map queue 1 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue input dscp-map queue 1 threshold 3 32
mls qos srr-queue input dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue input dscp-map queue 2 threshold 2 33 34 35 36 37 38 39 48
mls qos srr-queue input dscp-map queue 2 threshold 2 49 50 51 52 53 54 55 56
mls qos srr-queue input dscp-map queue 2 threshold 2 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue input dscp-map queue 2 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 3 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 2 4
mls qos srr-queue output cos-map queue 4 threshold 2 1
mls qos srr-queue output cos-map queue 4 threshold 3 0
mls qos srr-queue output dscp-map queue 1 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 3 threshold 3 32 33 34 35 36 37 38 39
mls qos srr-queue output dscp-map queue 4 threshold 1 8
mls qos srr-queue output dscp-map queue 4 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue output dscp-map queue 4 threshold 3 0 1 2 3 4 5 6 7
mls qos queue-set output 1 threshold 1 138 138 92 138
mls qos queue-set output 1 threshold 2 138 138 92 400
mls qos queue-set output 1 threshold 3 36 77 100 318
mls qos queue-set output 1 threshold 4 20 50 67 400
mls qos queue-set output 2 threshold 1 149 149 100 149
mls qos queue-set output 2 threshold 2 118 118 100 235
mls qos queue-set output 2 threshold 3 41 68 100 272
mls qos queue-set output 2 threshold 4 42 72 100 242
mls qos queue-set output 1 buffers 10 10 26 54
mls qos queue-set output 2 buffers 16 6 17 61
mls qos
crypto pki trustpoint TP-self-signed-2714204672
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2714204672
revocation-check none
rsakeypair TP-self-signed-2714204672
crypto pki certificate chain TP-self-signed-2714204672
certificate self-signed 01
308202A8 30820211 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
5C312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32373134 32303436 37323129 30270609 2A864886 F70D0109
02161A43 414C4741 52592D53 57495443 482E6A65 76636F2E 6C6F6361 6C301E17
0D393330 33303130 30303134 355A170D 32303031 30313030 30303030 5A305C31
2F302D06 03550403 1326494F 532D5365 6C662D53 69676E65 642D4365 72746966
69636174 652D3237 31343230 34363732 31293027 06092A86 4886F70D 01090216
1A43414C 47415259 2D535749 5443482E 6A657663 6F2E6C6F 63616C30 819F300D
06092A86 4886F70D 01010105 0003818D 00308189 02818100 B51A1916 B271C766
720F0D10 F924AB06 6EBA6133 463B29FD 8DC6EB88 4154F8D5 4CDCF783 F691E451
5E256154 503C6F3C 439CDD62 411E5341 26EC592C AB85B70C 2B52E50A 6F985683
39D5CEB0 5E728FE5 DDD87C73 63E3C16B 7E601A41 71D22BD5 A64EE5AD 1B6C6085
49895B73 7FBEAEFD 4E508A6A 03B1F3A9 FB9F3749 DC0FBAEF 02030100 01A37A30
78300F06 03551D13 0101FF04 05300301 01FF3025 0603551D 11041E30 1C821A43
414C4741 52592D53 57495443 482E6A65 76636F2E 6C6F6361 6C301F06 03551D23
04183016 8014B576 E9178368 4C104DE4 A1C08F8A DA74B2FB EA8C301D 0603551D
0E041604 14B576E9 1783684C 104DE4A1 C08F8ADA 74B2FBEA 8C300D06 092A8648
86F70D01 01040500 03818100 04B751B5 28603440 EADEB7D9 0C7B4191 11D5909D
98DEBCA4 6458AEBA C487DDE7 F97DD898 AD319989 43272DDD 1C10AA49 627EBF32
F38E0FD9 9CC5BA69 4986BEB5 BA9FCDEF 8E464607 75A49F78 C5E15873 EBA8FB81
833D17A4 6F528FAC C354CD59 2B9D4386 F7E40073 31DBF3E6 8F3D20B5 9492F468
EEF367D4 8A0B9375 29DA2D40
quit
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 333
name Vlan-333-Data
vlan 334
name Vlan-334-Voice
vlan 335
name Vlan-335-Management
vlan 933
name Vlan_Native
interface FastEthernet1/0/1
switchport access vlan 333
switchport mode access
switchport voice vlan 334
mls qos trust device cisco-phone
spanning-tree portfast
interface FastEthernet1/0/2
description Connection to Bell PSTN Router
interface FastEthernet1/0/3
interface FastEthernet1/0/4
interface FastEthernet1/0/5
interface FastEthernet1/0/6
interface FastEthernet1/0/7
interface FastEthernet1/0/8
interface FastEthernet1/0/9
interface FastEthernet1/0/10
interface FastEthernet1/0/11
interface FastEthernet1/0/12
interface FastEthernet1/0/13
interface FastEthernet1/0/14
interface FastEthernet1/0/15
switchport access vlan 335
interface FastEthernet1/0/16
no mdix auto
interface FastEthernet1/0/17
interface FastEthernet1/0/18
interface FastEthernet1/0/19
interface FastEthernet1/0/20
interface FastEthernet1/0/21
interface FastEthernet1/0/22
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
mls qos trust cos
auto qos voip cisco-phone
no mdix auto
interface FastEthernet1/0/23
interface FastEthernet1/0/24
interface FastEthernet1/0/25
interface FastEthernet1/0/26
interface FastEthernet1/0/27
interface FastEthernet1/0/28
interface FastEthernet1/0/29
interface FastEthernet1/0/30
interface FastEthernet1/0/31
interface FastEthernet1/0/32
interface FastEthernet1/0/33
interface FastEthernet1/0/34
interface FastEthernet1/0/35
interface FastEthernet1/0/36
interface FastEthernet1/0/37
interface FastEthernet1/0/38
interface FastEthernet1/0/39
interface FastEthernet1/0/40
interface FastEthernet1/0/41
interface FastEthernet1/0/42
interface FastEthernet1/0/43
interface FastEthernet1/0/44
interface FastEthernet1/0/45
interface FastEthernet1/0/46
interface FastEthernet1/0/47
interface FastEthernet1/0/48
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface FastEthernet2/0/1
interface FastEthernet2/0/2
interface FastEthernet2/0/3
interface FastEthernet2/0/4
interface FastEthernet2/0/5
interface FastEthernet2/0/6
interface FastEthernet2/0/7
interface FastEthernet2/0/8
interface FastEthernet2/0/9
interface FastEthernet2/0/10
interface FastEthernet2/0/11
interface FastEthernet2/0/12
interface FastEthernet2/0/13
interface FastEthernet2/0/14
interface FastEthernet2/0/15
interface FastEthernet2/0/16
interface FastEthernet2/0/17
interface FastEthernet2/0/18
interface FastEthernet2/0/19
interface FastEthernet2/0/20
interface FastEthernet2/0/21
interface FastEthernet2/0/22
interface FastEthernet2/0/23
interface FastEthernet2/0/24
interface FastEthernet2/0/25
interface FastEthernet2/0/26
interface FastEthernet2/0/27
interface FastEthernet2/0/28
interface FastEthernet2/0/29
interface FastEthernet2/0/30
interface FastEthernet2/0/31
interface FastEthernet2/0/32
interface FastEthernet2/0/33
interface FastEthernet2/0/34
interface FastEthernet2/0/35
interface FastEthernet2/0/36
interface FastEthernet2/0/37
interface FastEthernet2/0/38
interface FastEthernet2/0/39
interface FastEthernet2/0/40
interface FastEthernet2/0/41
interface FastEthernet2/0/42
interface FastEthernet2/0/43
interface FastEthernet2/0/44
interface FastEthernet2/0/45
interface FastEthernet2/0/46
interface FastEthernet2/0/47
interface FastEthernet2/0/48
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
interface Vlan1
no ip address
shutdown
interface Vlan333
ip address 10.3.0.1 255.255.255.0
ip helper-address 10.3.0.4
interface Vlan334
ip address 10.3.33.1 255.255.255.0
interface Vlan335
ip address 10.3.35.1 255.255.255.0
ip default-gateway 10.3.0.1
ip classless
ip forward-protocol udp bootpc
ip forward-protocol udp bootps
ip route 0.0.0.0 0.0.0.0 10.3.0.2
ip http server
ip http secure-server
ip tacacs source-interface Vlan333
logging trap debugging
logging 10.0.5.37
logging 10.0.57.104
access-list 57 permit 10.0.5.37
access-list 57 permit 10.0.57.0 0.0.0.255
access-list 57 deny any log
snmp-server community
snmp-server location
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps cluster
snmp-server enable traps entity
snmp-server enable traps cpu threshold
snmp-server enable traps vtp
snmp-server enable traps port-security
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps license
snmp-server enable traps config
tacacs-server host 10.0.0.29 key 7 096F6D482A2647
tacacs-server directed-request
radius-server source-ports 1645-1646
control-plane
banner motd ^CC
| WARNING |
| The programs and data stored on this system are licensed to or are |
| private property of this organization and are lawfully available |
| only to authorized users for approved purposes. Unauthorized access |
| to this system, or any program or data on this system is not |
| permitted. Unauthorized access beyond this point may lead to |
| prosecution. This system is subject to monitoring and anyone using |
| this system expressly consents to such monitoring. |
| If you are not an authorized user, DO NOT ATTEMPT TO LOG IN. |
^C
alias exec si sh ip int brief
line con 0
logging synchronous
length 40
width 120
line vty 0 4
access-class 57 in
logging synchronous
width 120
transport input telnet ssh
line vty 5 15
ntp clock-period 36028820
ntp server 10.0.5.47
end
11-25-2011 06:41 AM
1)you can remove ip helper-address on interface Vlan 333
2) have you got a route to 10.3.33.0/24 on your DHCP server ?
3) where is your DHCP server connected ?
Regards.
Alain
11-25-2011 06:47 AM
Hello Alain,
1. Yes I can remove the ip-helper on vlan 333
2. My DHCP server can ping 10.3.33.1 which is the switch itself.
3. The DHCP server is connected on FastE 1/0/14, should I change to trunk mode ?
Colin
11-25-2011 08:30 AM
no but you can remove the voice vlan from this port as well as the Qos trust device Cisco-phone.
are you sure your phones are receiving the correct VLAN info from CDP ? Are these Cisco Phones?
Regards.
11-25-2011 09:58 AM
Yes they are Cisco Phones.
sh cdp entry * shows the following....
Device ID: SEP58BC2775DD0C
Entry address(es):
IP address: 10.3.0.69
Platform: Cisco IP Phone 7942, Capabilities: Host Phone
Interface: FastEthernet1/0/16, Port ID (outgoing port): Port 1
Holdtime : 153 sec
Version :
SCCP42.9-1-1SR1S
advertisement version: 2
Duplex: full
Power drawn: 6.300 Watts
Power request id: 56588, Power management id: 3
Power request levels are:6300 0 0 0 0
Management address(es):
11-25-2011 12:24 PM
I ve had loads of issues like this before, re config for the DHCP server port with QOS and trunking etc
Like Alain has said
Reconfigure the DHCP server port to a purely access port in the data vlan
You say it is on int fas 1/0/14
change this to:-
desc *** DHCP SERVER ***
no switchport voice vlan 334
no mls qos trust device cisco-phone
Alex
11-30-2011 12:07 PM
Hey Guys,
Believe it or now, I am now have a total DHCP outage with any device that is connected to this switch stack. I am puzzled. Is there anything else I can look at or use to debug dhcp requests ?
Cheers
Colin
12-06-2011 04:23 AM
Finally found a solution to this mess.
Our Windows DHCP Server had "DHCP Filtering" enabled. As soon as I disabled this feature our clients began to grab ip's.
Unbelievable..
