Webcast-Catalyst9k
DHCP relay Agent
Dear All;
i need your advice
i have 1 switched network...details are here for your consideration.
enduser first switch is 2950....it has 5 Vlans...Vlan 10-20-30-40 and 50. then i have uplink to another layer 2 switch 3500. i just make these Vlan into this as well. then i have uplink to layer3 3750 fiber switch,. there i make all Vlan and assign the IP address which would be default gateway for the clients those are behind 2950 switch. for DHCP relay ...now i need to configure IP Helper-address on Vlan20...like
#Vlan 20
#ip address 1.1.1.1 255.0.0.0
#ip helper-addres 10.1.1.1
by doing this my DHCP relay would configure...i already check that my client is able to ping the DHCP server.
is this complete configuration..?
please advice
regards
soshomile
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: DHCP relay Agent
Hello Soshomile,
if 10.1.1.1 is the DHCP server ip address you are fine.
by default the bootpc requests are converted in packets with destination 10.1.1.1 and with a gateway field 1.1.1.1 that allows the DHCP server to assign a correct ip address from the correct pool to the requesting client.
DHCP server answer is sent to 1.1.1.1 and the router will send out a broadcast for the original client with the answer (the answer contains the MAC address of the requesting client)
Hope to help
Giuseppe
1 REPLY
Hello Soshomile,
Hope to help
Giuseppe
140
