Community Member
DHCP Reservation Problem
I have the following problem:
I have created 3 DHCP pools (see below).
ip dhcp pool sdm-IRB1-Pool-AirTraffic
host 10.0.0.250 255.255.255.0
hardware-address 0100.19d1.7fcc.26
default-router 10.0.0.254
dns-server 194.x.x.100 194.168.8.100
domain-name oxfd.cable.ntl.com
client-name AirTraffic
ip dhcp pool sdm-IRB1-Pool-Aviator-3G
host 10.0.0.251 255.255.255.0
hardware-address 0100.21e9.2a34.ce
dns-server 194.168.4.100 194.168.8.100
client-name Aviator-3G
network 10.0.0.0 255.255.255.0
I am trying to map the dhcp leases for the AirTraffic and Aviator-3G clients to specific IP addresses.
The problem is that when the client attaches to the network they fail to receive the reserved IP address and instead receive an IP address from the main pool “sdm-IRB1-Pool”. I have tried removing the “sdm-IRB1-Pool” but this fails to give the client an IP address allocation.
When the client attaches to the network the follow debug output is created.
000535: Jan 22 19:23:55.424 London: %DOT11-6-DISASSOC: Interface Dot11Radio0/0/0, Deauthenticating Station 0021.e92a.34ce Reason: Sending station has left the BSS SSID[avenue]
000536: Jan 22 19:24:00.952 London: %DOT11-6-ASSOC: Interface Dot11Radio0/0/0, Station 0021.e92a.34ce Associated SSID[avenue] AUTH_TYPE[OPEN] KEY_MGMT[WPAv2 PSK]
000537: Jan 22 19:24:01.284 London: DHCPD: DHCPREQUEST received from client 0100.21e9.2a34.ce.
000538: Jan 22 19:24:01.284 London: DHCPD: Sending notification of ASSIGNMENT:
000539: Jan 22 19:24:01.284 London: DHCPD: address 10.0.0.2 mask 255.255.255.0
000540: Jan 22 19:24:01.284 London: DHCPD: htype 1 chaddr 0021.e92a.34ce
000541: Jan 22 19:24:01.284 London: DHCPD: lease time remaining (secs) = 86400
000542: Jan 22 19:24:01.284 London: DHCPD: Appending default domain from pool
000543: Jan 22 19:24:01.284 London: DHCPD: Using hostname 'Aviator-3G.oxfd.cable.ntl.com.' for dynamic update (from hostname option)
000544: Jan 22 19:24:01.284 London: DHCPD: Sending DHCPACK to client 0100.21e9.2a34.ce (10.0.0.2).
000545: Jan 22 19:24:01.284 London: DHCPD: creating ARP entry (10.0.0.2, 0021.e92a.34ce, vrf 0).
000546: Jan 22 19:24:01.288 London: DHCPD: unicasting BOOTREPLY to client 0021.e92a.34ce (10.0.0.2).
A complete copy of the running config is attached.
Any help would be much appreciated.
1 ACCEPTED SOLUTION
Bronze
Re: DHCP Reservation Problem
Daniel-
Instead of using the hardware-address line, replace it with "client-identifier" instead, so
client-identifier 0100.19d1.7fcc.26
etc.
HTH,
Paul
Bronze
Daniel-
etc.
HTH,
Paul
Community Member
Many thanks Paul. That worked straight away!!
1887
