DHCP static mapping
I've been playing with the DHCP server function provided by the IOS.
After some test I've run into this problem:
Setting up a pool = everything works
Setting up a static mapping = it works ONLY if I use the client-id command, but not the hardware-address.
The cisco device is a 3550 and the client is a windows xp laptop whom nic MAC address is: 0012.3f21.9b4d
Enabling Debug on the 3550 I get this:
02:46:21: DHCPD: DHCPREQUEST received from client 0100.123f.219b.4d.
Q1)If I use this number as client-identifer as mentioned above, it works fine! But why is the client-id 01+MAC?
Q2)According to the cisco site, I can use either network-address or client-idenfier.
Why if I use the network-address isn't working?
ip dhcp excluded-address 33.33.33.1 33.33.33.99
ip dhcp pool c1720
host 33.33.33.150 255.255.255.0
hardware-address 0012.3f21.9b4d
client-name d410
domain-name static.com
ip dhcp pool TEST
network 33.33.33.0 255.255.255.0
dns-server 33.33.33.1
default-router 33.33.33.1
no ip domain-lookup
ip dhcp-server 127.0.0.1
interface fastethernet 0/2
ip address 33.33.33.1 255.255.255.0
FULL DEBUG MESSAGES when I've configed the hardware-address. As you can see it's picking up the address from the generic pool rather than from the static mapping:
03:03:05: DHCP opt82: extract option 82.
03:03:05: DHCPD: DHCPDISCOVER received from client 0100.123f.219b.4d on interface FastEthernet0/2.
03:03:05: DHCPD: Sending DHCPOFFER to client 0100.123f.219b.4d (33.33.33.100).
03:03:05: DHCPD: creating ARP entry (33.33.33.100, 0012.3f21.9b4d).
03:03:05: DHCPD: unicasting BOOTREPLY to client 0012.3f21.9b4d (33.33.33.100).
03:03:05: DHCPD: DHCPREQUEST received from client 0100.123f.219b.4d.
03:03:05: DHCPD: Sending DHCPACK to client 0100.123f.219b.4d (33.33.33.100).
Re: DHCP static mapping
From what I found, the dhcp server will look at the client indentifier in the dhcp discover packet and use that, not the mac address. How do you know what the client identifier is? You have to either use a sniffer or turn on debugs on the dhcp server. Since you have doen the debug already then you already know what client-identifier to use. For example:
ip dhcp pool c1720
client-identifier 0100.123f.219b.4d
client-name d410
Try this and it should assign that host address to that device with mac-address 0012.3f21.9b4d. Why does it add the "01"? That I still have to look around. I found that in some cases too, that some devices uses a uses ASCII hex characters.
I you use an ascii hex to ascii symbol conversion chart you see the following.
There is a complete chart at
http://www.ascii.cl/index.htm
So, in some cases you will see a DHCP binding to some mac-address that looks like:
0063.6973.636f.2d61.6162.622e.6363.3030.2e30.3630.302d.4574
If you use the ascii symbol conversion above it will give you "nul c i s c o - - v l 1"
Please rate all posts.
Thanks!
That really helps!
Regarding the 01, I've got an idea...
I think it is related to the "option 82".
If I'm not mistaken, this is the class paramenter.
The class is a new IOS addition (although it's an old RFC standard), and permits to assign different IPs based on the client classes (rather than client-id or mac address).
Refering to the doc CD there should be a *class* command in both global and dhcp poool config.
I've looked for it on all the router I've got (about 12) with different up2date IOS versions and I wasn't able to find it.
Could you please clarify the las part of your post?
From the example you've given
2e30.3630.302d.4574 is the mac address, but what's again the
0063.6973.636f.2d61.6162.622e.6363.3030 preceding?
Thanks!
Some clients/hosts (I think like CE500 that is configured to get IP address through DHCP) send their client-identifier in ascii hexadecimal character and it would like as such:
If you use the ascii hex to ascii symbol conversion chart you see the following.
you will find that
0063.6973.636f.2d30.3030.352e.3331.3365.2e39.6330.302d.566c.31
nul c i s c o - 0 0 0 5 . 3 1 3 e . 9 c 0 0 - v l 1
2e30.3630.302d.4574 is NOT the mac address.
I was actually translating using the ASCII column, but of course I've got to use the HEX one instead.
Thanks!
Silver
http://www.cisco.com/en/US/products/ps6441/products_configuration_guide_chapter09186a00805ecec2.html
"Specifies a hardware address for the client.
or
Specifies the unique identifier for Microsoft DHCP clients.
?Microsoft clients require client identifiers instead of hardware addresses. The unique identification of the client is specified in dotted hexadecimal notation, for example, 01b7.0813.8811.66, where 01 represents the Ethernet media type. "
hope this help
Andrea
1210
