Community Member
differ between frame relay and VPN
can somebody tell me what is the diff between frame relay and VPN in detail ?..
i had searched the sites but i am not getting concrete answers..
help me out...
1 REPLY
Bronze
Re: differ between frame relay and VPN
You can't differ between F.R and VPN.
The F.R is one of the WAN connection like TDM, ISDN...
And if you mean VPN as IPSec VPN, this technology is used over the public network to be able to connect your private network, this will encrypt your traffic going to your private network in a tunnel.
Some helpful documents,
F.R -> http://www.cisco.com/univercd/cc/td/doc/cisintwk/ito_doc/frame.htm
VPN -> http://compnetworking.about.com/od/vpn/l/aa010701a.htm
let me know if you have any questions!
Please rate if it does.
Abd Alqader
97
