Webcast-Catalyst9k
Differece B/T Giga bit and FE Cross and Stright Cable. ???
Is there any pin configuration difference between gigabit and simple Fe cable (strigth and cross)
I am asking it about the pin configurations.
Re: Differece B/T Giga bit and FE Cross and Stright Cable. ???
Short answer no.
Long answer FE and GE use the same pysical media, the exception being the 1000base-SX or LX which use fiber.
For 1000Base-T I have never seen a GE port that didn't automtatically work out if it needed a streight or crossover connection, so in every case I have seen, a streight cable will work, as will a crossover.
the pinouts for 100MB are:
Straight (only pins 1,2,3,6 are used)
1-1
2-2
3-3
4-4
5-5
6-6
7-7
8-8
Cross (only pins 1,2,3, and 6 are used)
1-3
2-6
4-4
5-5
7-7
8-8
The pinouts for 1000MB are:
Straight (all eight pins are used)
1-1
2-2
3-3
4-4
5-5
6-6
7-7
8-8
Cross (all eight pins are used)
1-3
2-6
4-7
5-8
Check this link as well for some background info and useful drawings:
LAN Wiring & Pinouts
10base-T, 100base-TX/T4, 1000base-T
http://www.zytrax.com/tech/layer_1/cables/tech_lan.htm
HTH,
GNT
273
