Difference between C7200p and c7200
sampathkumar.s
I notice some of the IOS using c7200p-advipservicesk9-mz.124-24.T3.bin and c7200-advipservicesk9-mz.124-24.T3.bin,
We are running cisco 7206 VXR Router with NPE-G2. what is the benefit of using c7200p instead only c7200?
The c7200p image will not work in the NPE-G1 or older. Similar issue if you use the c7200 image on the NPE-G2, it will not work at all.
jerry
Giuseppe Larosa
Hello Sampathkumar.s,
the p means NPE-G1 or NPE-G2 so you need to use a release c7200p on your device is not a choice
the c7200 is good for older NPE
see
sh ver | inc image
System image file is "disk2:c7200p-advsecurityk9-mz.124-20.T.bin"
sh ver | inc processor
Cisco 7206VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memory.
on an old C7200 instead:
sh ver | inc image
System image file is "slot0:c7200-js-mz.121-21.bin"
cisco 7206 (NPE150) processor (revision B) with 57344K/8192K bytes of memory.
Hope to help
Giuseppe
Thanks Guisppe,
We have one router running NPE-G1 without P IOS, will it make any impact?
------------------ show version ------------------
Cisco IOS Software, 7200 Software (C7200-ADVENTERPRISEK9-M), Version 12.4(11)T2, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Tue 01-May-07 04:19 by prod_rel_team
ROM: System Bootstrap, Version 12.3(4r)T3, RELEASE SOFTWARE (fc1)
BOOTLDR: 7200 Software (C7200-KBOOT-M), Version 12.3(9), RELEASE SOFTWARE (fc2)
XXX uptime is 20 weeks, 4 days, 6 hours, 31 minutes
System restarted at 05:24:24 UTC Sun Jun 24 2007
System image file is "disk2:c7200-adventerprisek9-mz.124-11.T2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 7206VXR (NPE-G1) processor (revision B) with 983040K/65536K bytes of memory.
jerry
