Different MTU size's for ping command
Ahmed Mukhtar
Hello
I have a question which may sound silly...But if i want to ping any ip say i want to ping 1.1.1.1....so can i ping it with Multtiple MTU sizes???
like when i hit the command
Rx# ping 1.1.1.1
Then can i make each ping go with a different a Different MTU size if i want ??? by any command or something??
Thank you
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
As the other posters have already noted, extended ping, i.e. entering ping followed by an enter, will prompt you for various options including size (also offers a range of size too).  However, the later IOSs also offer some of those options on the command line, size being one of them.  Enter ping and question mark to see if those additional options are offered.
10 Replies 10
cadet alain
The extended ping command can do this for you.
http://www.cisco.com/c/en/us/support/docs/ip/routing-information-protocol-rip/13730-ext-ping-trace.html
Alain
I want the output to be something like this....
Means each ping Goes with a different Byte Size or MTU size....
Reply from 192.168.1.1: bytes=32 time=2ms TTL=64
Reply from 192.168.1.1: bytes=64 time=2ms TTL=64
Reply from 192.168.1.1: bytes=100 time=2ms TTL=64
Reply from 192.168.1.1: bytes=150 time=7ms TTL=64
Its just an example i took but it clears the concept i think
can this be done??
Dragan Ilic
Level 4
Level 4
just hit "ping" and "enter" and you will see what options you have there...
HTH,
Dragan
HTH,
Dragan
can this be done??
Joseph W. Doherty
Disclaimer
Posting
Ahmed Mukhtar
can this be done??
Well you didn't even try to test how extended ping works...
I hope this thread will clarify things for you:
https://supportforums.cisco.com/thread/344529
HTH,
Dragan
HTH,
Dragan
Disclaimer
Posting
You can do something similar with extended ping, e.g.:
router#ping
Protocol [ip]:
Target IP address: 10.178.0.3
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface:
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]: y
Sweep min size [36]: 36
Sweep max size [18024]: 1500
Sweep interval [1]: 32
Sending 230, [36..1500]-byte ICMP Echos to 10.178.0.3, timeout is 2 seconds:
Success rate is 100 percent (230/230), round-trip min/avg/max = 1/2/17 ms
Ahmed Mukhtar
can this be done??
