05-25-2007 10:11 AM - edited 03-03-2019 05:09 PM
05-25-2007 10:35 AM
Hey Friend,
Here you go..I made this link public for you and it should not pormpt your for any username and password now
http://www.cisco.com/warp/public/473/81.html#diff
Ankur
*Pls rate all helpfull post
05-25-2007 10:18 AM
Hi Friend,
This link will give you complete picture of CATOS and IOS operation
http://www.cisco.com/en/US/products/hw/switches/ps708/products_white_paper09186a00800c8441.shtml
Also check this link which will specify you the difference between the two
http://www.cisco.com/warp/customer/473/81.html#diff
Ankur
05-25-2007 10:31 AM
Thanks Ankur!!
I'm looking for diff. bet.two.
It seems 2nd link can give me its idea ,but its not allowing me get inside.It asking user id & password.I dont have any user id/Password other cisco user ID.
Can u give some points from that link in reply.
Thanks.
05-25-2007 10:35 AM
Hey Friend,
Ankur
