06-14-2008 11:57 AM - edited 03-03-2019 10:21 PM
what is the function wise diffrence between both the cards for E1 link.
Solved! Go to Solution.
06-14-2008 04:48 PM
Hi, beside different generations, one is an NM the other a an HWIC. Both wold work foran E1 circuit. The g.703 variant is needed only if you have an unframed circuit and want to us it in full.
06-14-2008 04:48 PM
06-15-2008 09:27 AM
Hi Ajay,
In addition to what Paolo has mentioned, NM-1CE1T1-PRI module supports only DATA, no voice support on this module.
-> Sushil
06-15-2008 12:51 PM
Yes, and in fact the evolution of it is the new HWIC-1CE1T1-PRI that you may want to consider as well.
04-27-2009 06:16 AM
Hi guys, this HWIC-1CE1T1-PRI is supported in the Cisco 3825? It can be inserted in the HWIC slot without the need of a Network Module?
Thanks for making clear.
All the best
David
04-27-2009 07:02 AM
Yes, it can provided you have an IOS version with support for that.
