Diffrence between NM-1CE1T1-PRI= and VWIC2-1MFT-G703=
what is the function wise diffrence between both the cards for E1 link.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Diffrence between NM-1CE1T1-PRI= and VWIC2-1MFT-G703=
Hi, beside different generations, one is an NM the other a an HWIC. Both wold work foran E1 circuit. The g.703 variant is needed only if you have an unframed circuit and want to us it in full.
Hi Ajay,
In addition to what Paolo has mentioned, NM-1CE1T1-PRI module supports only DATA, no voice support on this module.
-> Sushil
Yes, and in fact the evolution of it is the new HWIC-1CE1T1-PRI that you may want to consider as well.
Bronze
Hi guys, this HWIC-1CE1T1-PRI is supported in the Cisco 3825? It can be inserted in the HWIC slot without the need of a Network Module?
Thanks for making clear.
All the best
David
Yes, it can provided you have an IOS version with support for that.
209
