disable 2800 series' USB port?
randomjoe1
is there a command to disable the USB port on a 2800 router?
11 Replies 11
podhillo
Hi ,
please try to get into the interface using the "interface usd" command and try a "shut" and check if it works.
interface usb
To enter the interface configuration mode for the Universal Serial Bus (USB) interface, use the interface usb command in global configuration mode.
Cisco uBR925 cable access router, Cisco CVA122 Cable Voice Adapter
interface usb number
Syntax Description
number
Identifies the USB interface (always 0).
Command Default
Disabled
Command Modes
Global configuration
show usb port
To sisplay USB root hub port information, use the show usb port command in privileged EXEC mode.
show usb port [port-number]
Syntax Description
port-number
(Optional) Displays information only for a specified. If the port-number is not issued, information for all root ports will be displayed.
Command Modes
Privileged EXEC
Command History
Release  Modification
12.3(14)T
This command was introduced.
Examples
The following example shows how to enter interface configuration mode for the USB interface and then to display the available commands:
Router(config)# interface usb 0
Router(config-if)#?
Interface configuration commands:
access-expression Build a bridge boolean access expression
arp Set arp type (arpa, probe, snap) or timeout
bandwidth Set bandwidth informational parameter
bridge-group Transparent bridging interface parameters
carrier-delay Specify delay for interface transitions
cdp CDP interface subcommands
crypto Encryption/Decryption commands
custom-queue-list Assign a custom queue list to an interface
default Set a command to its defaults
delay Specify interface throughput delay
description Interface specific description
exit Exit from interface configuration mode
fair-queue Enable Fair Queuing on an Interface
h323-gateway Configure H323 Gateway
help Description of the interactive help system
hold-queue Set hold queue depth
ip Interface Internet Protocol config commands
keepalive Enable keepalive
load-interval Specify interval for load calculation for an
interface
logging Configure logging for interface
mac-address Manually set interface MAC address
max-reserved-bandwidth Maximum Reservable Bandwidth on an Interface
mtu Set the interface Maximum Transmission Unit (MTU)
no Negate a command or set its defaults
ntp Configure NTP
priority-group Assign a priority group to an interface
random-detect Enable Weighted Random Early Detection (WRED) on an
Interface
service-policy Configure QoS Service Policy
shutdown Shutdown the selected interface
snmp Modify SNMP interface parameters
standby Interface HSRP configuration commands
timeout Define timeout values for this interface
traffic-shape Enable Traffic Shaping on an Interface or
Sub-Interface
transmit-interface Assign a transmit interface to a receive-only
interface
tx-ring-limit Configure PA level transmit ring limit
Please let me know if this was helpful.
podhillo
could not 'int usb x', got the error ^ under the u.  the show command worked and that helps as well.  thanks!
Just because the status says it's "Disabled" doesn't really mean it's disabled.  It means that if you stick a USB flash in there the hardware will detect it and enable.
I have no idea why you want to disable this but I've been, in two occassions, use the USB to boot the router because of corrupt IOS.
why would I want to disable the usb port?  security.  I have a router in a physically insecure area and don't want someone plugging in their iphone to charge it.  There are other ways to recover a router, my laptop has a CF reader and I have a spare card.  and if you change the baudrate to 115200 you could transfer an IOS image in 6 minutes
Errr ... The USB port won't or doesn't work like that.  I hope I get the term right, but the USB port(s) of the appliance works as an Input/Output (I/O) device and not as a multi-function dock.
OK background on why I started the thread...  we got a log msg recv'd
saying a usb device was plugged in (we NEVER use usb)
.  so we logged in and decided to find out what was plugged in.  upon performing the
dir command, the router proceeded to crash and reboot.  ya.  The router is off site, so while the field eng. drove on site, we were betting on what happenned.  Iphone does not get recognized, BUT I COULD charge my blackberry 8820 off a router, and it mounted the microSD card and I was able to browse it from the router.  Could not reproduce the crash though on a lab 2800 running the same code.
so there, the usb port does have power and could indeed charge a blackberry 8800 series phone
Thanks for the heads up.  Never knew about this.
there is no reason why anyone should know that info...  cause really, who would think about chargin
g a phone on a router?  We tried to just
to try and reproduce the crash (what else would someone working in a warehouse plug into a router
Glad I could be of any help!
podhillo
Dear Podhillo,
        Simillarly can you tell me the command to check the USB port of 7604 Core router.
Thanks in Advance
Senthil
If you are using Sup32 or Sup720, there's no need to check.  These cards do not support USB.  As a matter of fact, the USB is software disabled by the IOS all the time.
