Bronze
Disable Cellular CDMA/GSM module advertments
We have the Cisco Cellular CDMA and GSM modules installed in our 881G routers.
Everything works VERY well and 3G is suppppper fast.
However, I would like to somehow disable the advertisement of my radio module to other subscribers on the provider network.
Also when I show users, I am seeing the PPP connection and Verizon tells me to disable SSID to remove the PPP connection.
881G router# sh users
Line User       Host(s)          Idle          Location
*0   Con 0      BR549 idle       00:00:00
3   tty  3     Async interface  00:00:01      PPP: public ip address
EX Verizon tech support insists I should disable the SSID.
I understand wireless 802.11 SSID but cannot locate ANYTHING on SSID for CDMA or GSM cellular.
ANYONE have any idea(s)?
As always, I "WE" appreciate the assistance.
If requested, I can post the actual config making this cellular card operational.
Frank
422
