Disable HDLC
grungerokker13
We have a cisco router in another location that has both ARPA and HDLC entries. We don't use HDLC and we don't need it at all. How do I get rid of these sessions and disable them from reoccurring.
They are only coming in on serial0/0 in the interface, there is nothing to do with HDLC anywhere. I went into that interface and used the "no encapsulation HDLC" command. This didn't solve the problem.
I would like to avoid blocking specific IPs/MACs. Is there a way to completely disable HDLC on the router itself.
Any Help is appreciated.
5 Replies 5
Giuseppe Larosa
Hello Ross,
HDLC is a point-to-point serial encapsulation that can be used on a serial interface. Actually Cisco implements a proprietary version that includes a protocol field.
What is unclear is where you see mixed ARPA entries and HDLC entries
and you speak of IP/MACs.
You probably have some form of bridging over the WAN serial interface I don't see other reason to learn MAC addresses on a serial interface.
So probably if this is not needed anymore you need to remove commands like
bridge-group 1
under the serial interface configuration
But be careful if bridging over serial was configured was needed in the past.
Hope to help
Giuseppe
Sorry I left that part out. I found those entries in with the show arp command.
Hello Ross,
so you mean that in a sh arp you see entries with encapsulation HDLC ?
I've never seen this
May I ask you to post a filtered version of the configuration of your router ?
What plaform ? IOS version ?
I may be missing something but you can get better help if you provide us more details
Hope to help
Giuseppe
Also I don't believe "no encapsulation hdlc" is the exact command you want to be using here; it's best to specifically enable a different form of serial encaps (be it frame, PPP, or whichever).
Cisco's proprietary HDLC is the default encapsulation type for their serial interfaces, so if you use a "no encapsulation {anything}" command, the interface will default back to HDLC encapsulation, no matter which encaps type you were trying to disable.
michael3046
Is this interface doing IP or Packet over SONET? This could be the reason for having HDLC entries in your ARP cache.
http://www.tkn.tu-berlin.de/curricula/ss02/vl-bbn/Folien/SS2002-IP_over_SONET-4up.pdf
