Community Member
Disconnecting Interface
I have a newly installed HWIC 1FE card that I setup as a DMZ port to a public multihomed web server. My issue is that the connection from the HWIC and the External NIC on the web server keep losing connection. I have configured the default gateways according to Microsofts best practices as there appears to be a dead gateway issue if you configure both interface cards with a default gateway. Now I am wondering if my router hwic card is hitting some sort of idle time out. I used this docuementation for my DMZ setup
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_configuration_example09186a0080094111.shtml
interface FastEthernet0/2/0
description DMZ port for raleigh enterprise reporting system
ip address 192.168.50.1 255.255.255.0
ip access-group 111 in
ip nat inside
no ip virtual-reassembly
ip route-cache policy
ip tcp adjust-mss 1400
ip policy route-map test
duplex full
speed 100
FastEthernet0/2/0 is up, line protocol is up
Hardware is FastEthernet, address is 0019.561f.fc59 (bia 0019.561f.fc59)
Description: DMZ port for raleigh enterprise reporting system
Internet address is 192.168.50.1/24
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:03:23, output 00:00:08, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
65583 packets input, 64918142 bytes
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
156447 packets output, 34481803 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets
17 lost carrier, 0 no carrier
Any suggestions?
1 REPLY
Re: Disconnecting Interface
Your interface is configured as nat inside.
There might be a translation timeout.
The same might be true for the timeouts with ip inspect.
How long does it take for a session to die?
Initial troubleshooting should try to reproduce this without nat or with modified timeouts.
regards,
Leo
113
作成コンテンツを作成するには してください
