Webcast-Catalyst9k
Discussion on GRE Tunnel and GRE Tunnel Configuration
Can someone please point me to some good document discussing GRE Tunnel and GRE Tunnel Configuration Examples?
Everyone's tags (1)
Re: Discussion on GRE Tunnel and GRE Tunnel Configuration
you can find an overview here:
Technology Support: IP Tunneling
Some documets to begin with:
GRE Overview and Troubleshooting (a very nice summary)
Implementing Tunnels (contains some GRE parts)
Why Can't I Browse the Internet when Using a GRE Tunnel (Troubleshooting)
Resolve IP Fragmentation, MTU, MSS, and PMTUD Issues with GRE and IPSEC (Troubleshooting)
Rolf
Super Bronze
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Rolf's references cover GRE very well.
Just wanted to emphasis, some of the "optional" settings can be advantageous.  First, I like using "keepalive 1".  This insures tunnels goes "down" if reachability is lost to other side.  This is handy even on links where you're running a dynamic routing protocol if you're also running SNMP monitoring, as the latter usually "alarms" well when an interface goes down and perhaps not so well when a routing protocol loses a neighbor.
Using mss-adjust (if supported) and the correct MTU related commands helps deal with fragmentation issues which often are adverse to performance.  Do, though, keep in mind, IP/TCP overhead can be larger than 40 bytes, so setting mss-adjust to 1436 isn't a guarantee of success even with end-to-end Ethernet supporting 1500 MTU.
268
