Webcast-Catalyst9k
DLSW+ very very very Slow throughput
Hi all.
We have realized a test dlsw connection (all via ethernet), between two as400 systems.
We have tried first a file transfer using a back-to-back connection (using a crossover cable), and time to complete copy is 4 minutes.
So we have tried dlsw:
as400_1----r1--------r2-----as400_2
and performance is 4 hours (!!!!!).
We have checked all checkable, duplex mismatch (nothing), cable, ios releases, changed routers, but file transfer is very slow...
We understand that we can't obtain same performance like with a crossover cable, but I think that 4 hours is too much...
Configuration of routers are specular, first is:
service password-encryption
logging buffered 51200 warnings
enable secret 5 <removed>
enable password 7 <removed>
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip cef
ip tcp window-size 750000
ip tcp path-mtu-discovery
no ip domain lookup
dlsw local-peer peer-id 172.20.17.17 init-pacing-window 300 max-pacing-window 650
dlsw remote-peer 0 tcp 172.20.16.16 tcp-queue-max 500
dlsw bridge-group 5
interface FastEthernet0/0
description SNA
ip address 172.20.17.17 255.255.255.0
speed 100
full-duplex
bridge-group 5
interface FastEthernet0/1
description DLSW
ip address 172.23.65.38 255.255.255.252
speed 100
full-duplex
ip route 172.20.16.0 255.255.255.0 172.23.65.37
control-plane
bridge 5 protocol ieee
thanks
VIP Purple
Re: DLSW+ very very very Slow throughput
can you do a ´show tcp´ on both routers and check for if both routers are ´path mtu capable´ ?
Router#sow tcp
Flags: higher precedence, retransmission timeout, path mtu capable
Also, what is the ´max data segment´ for both routers (same command):
Datagrams (max data segment is 1460 bytes)
You might want to try and set the ´ip tcp adjust-mss´ value to e.g. 1492 on your FastEthernet interfaces...
GP
Have you tried: bridge 5 route ip?
Thanks.
Why:
bridge 5 route ip
We need to transport SNA and not ip traffic....
are the as400 and the routers hard wired together or are they connected via hub or switch ?
Are there any errors on the ethernet interfaces ?
No, there is any error in the interfaces...
AS400 and routers are connected through a crossover cable (I've used one of these to try AS400 to AS400 direct connection and all work properly...)
255
