DMVPN behind NAT
We are currently setting up a DMVPN cloud for the backup to our MPLS and have choosen to use ASAs in front of the routers for a number of reasons.
Currently our setup looks like:
Spoke/Branch MPLS/VPN Router <------> ASA <------> INTERWEBS <------> ASA <------> Hub DMVPN Router
I am currently testing in lab and so far we have been able to setup NAT on the ASAs, link up the tunnel running GRE and NHRP, and build an eBGP session over the tunnel, but the moment we attempt to encrypt the tunnel on the routers the link drops and fails to establish.
For the lab, both ASAs are setup with simple 1 to 1 static NAT statements and an ANY/ANY statement for traffic coming into the 2 routers.
We are getting P1 completion, QM_IDLE, on both sides, but it seems to be failing on P2.  My best guess at this point is because we are natting the traffic and the src/dst (local/remote) pairs for the tunnel don't match but I have exhahusted my resoures on how to resolve it.  Any help would be greatly apprciated.
For the lab, we are using 172. for WAN/Local addresses and 192.168 addresses to simulate the internet.
Hub ASA is translating f0/0 on the hub router to 192.168.1.3
Spoke ASA is translating F0/1 on the spoke router to 192.168.2.3
Relavent Router configurations are as follow:
HUB:
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp key cisco address 0.0.0.0 0.0.0.0
crypto isakmp nat keepalive 30
crypto ipsec transform-set esp-3des-sha esp-3des esp-sha-hmac
mode transport
no crypto ipsec nat-transparency udp-encaps
crypto ipsec profile vpn-dmvpn
set transform-set esp-3des-sha
interface Loopback0
ip address 172.21.10.3 255.255.255.255
interface Tunnel0
description DMPVPN Tunnel
bandwidth 10000
ip address 172.20.10.1 255.255.255.0
no ip redirects
ip mtu 1440
ip nhrp authentication cisco
ip nhrp map multicast dynamic
ip nhrp network-id 105600
ip nhrp holdtime 300
tunnel source FastEthernet0/0
tunnel mode gre multipoint
tunnel key 105600
tunnel protection ipsec profile vpn-dmvpn
interface FastEthernet0/0
ip address 172.21.10.30 255.255.255.252
speed 100
full-duplex
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
router eigrp 65010
network 172.21.10.3 0.0.0.0
network 172.21.10.28 0.0.0.3
no auto-summary
router bgp 65010
no synchronization
bgp log-neighbor-changes
timers bgp 5 20
neighbor 172.20.10.90 remote-as 65090
neighbor 172.21.10.1 remote-as 65010
neighbor 172.21.10.1 update-source Loopback0
neighbor 172.21.10.1 next-hop-self
no auto-summary
SPOKE:
encr 3des
group 2
crypto isakmp key cisco address 192.168.1.3
mode transport
interface Loopback0
ip address 10.90.1.1 255.255.0.0
interface Tunnel0
description DMVPN Tunnel
bandwidth 10000
ip address 172.20.10.90 255.255.255.0
ip mtu 1440
ip nhrp map 172.20.10.1 192.168.1.3
ip nhrp map multicast 192.168.1.3
ip nhrp nhs 172.20.10.1
tunnel source FastEthernet0/1
tunnel destination 192.168.1.3
tunnel key 105600
ip address 172.21.90.6 255.255.255.252
speed 100
full-duplex
ip address 172.21.90.29 255.255.255.252
duplex auto
speed auto
router bgp 65090
no synchronization
network 10.90.0.0 mask 255.255.0.0
neighbor 172.20.10.1 remote-as 65010
neighbor 172.21.90.5 remote-as 1
no auto-summary
Everyone's tags (2)
Re: DMVPN behind NAT
NAT-T disabled on both ends? Did you try it with NAT-T enabled?
HTH,
Lei Tian
We've tried it both with crypto ipsec nat-transparency udp-encapsulation turned on and off with no difference.
One error message of note, we are receving these messages on both ends.
Mar  1 15:55:27.191: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=172.21.90.29, prot=50, spi=0xFF0209EE(4278323694), srcaddr=192.168.1.3
Mar  1 15:49:28.355: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=172.21.10.30, prot=50, spi=0xFF150A1E(4279568926), srcaddr=192.168.2.3
So I'm not sure if NAT-T is completely working.
Is UDP 4500 permit on ASA?
HTH,
Lei Tian
yup, ASAs are set to any-any for testing.
We were able to resolve this by switching from PSK to RSA-SIG and making sure tunnel mode was enabled correctly on both ends.  Aparently DMVPN doesn't work with NAT and PSK but it works fine with RSA-SIG.
Hmm, that doesn't sound right, but thanks for the update!
1529
