DMVPN dual HUB issue
Hi all, I hope you can help me
issue: Eigrp neighborship is flapping between DMVPN spoke and hub router, we have 2 hub router for redundancy.
The flapping is only with one tunnel (to US).
Main hubs:
US: 10.32.170.1
UK: 10.24.170.1
Spoke:
Tunnel1                    10.24.170.35    YES NVRAM  up                    up  to UK
Tunnel2                    10.32.170.35    YES NVRAM  up                    up  to US
the source in the spoke router is Ethernet1 in both tunnels
Spoke1#sh runn int tun1
Building configuration...
Current configuration : 405 bytes
interface Tunnel1
bandwidth 1000
ip address 10.24.170.35 255.255.255.0
ip mtu 1352
ip nhrp authentication donttell
ip nhrp map 10.24.170.1 216.40.52.7
ip nhrp network-id 169
ip nhrp holdtime 300
ip nhrp nhs 10.24.170.1
ip route-cache flow
ip tcp adjust-mss 1200
delay 1000
tunnel source Ethernet1
tunnel destination 216.40.52.7
tunnel key 100000
tunnel protection ipsec profile PRO
end
Spoke1#sh runn int tun2
Current configuration : 406 bytes
interface Tunnel2
bandwidth 256
ip address 10.32.170.35 255.255.255.0
ip mtu 1352
ip nhrp map 10.32.170.1 216.40.48.53
ip nhrp network-id 170
ip nhrp nhs 10.32.170.1
ip route-cache flow
delay 1500
tunnel destination 216.40.48.53
tunnel key 100001
end
log:
ep  5 21:19:26 Summer: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 10.32.170.1 (Tunnel2) is up: new adjacency
Sep  5 21:47:24 Summer: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 10.32.170.1 (Tunnel2) is down: Peer goodbye received
Sep  5 21:47:24 Summer: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 10.32.170.1 (Tunnel2) is up: new adjacency
Sep  5 21:50:19 Summer: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 10.32.170.1 (Tunnel2) is down: Peer goodbye received
Sep  5 21:50:19 Summer: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 10.32.170.1 (Tunnel2) is up: new adjacency
Sep  5 22:05:21 Summer: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 10.32.170.1 (Tunnel2) is down: Peer goodbye received
Sep  5 22:05:21 Summer: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 10.32.170.1 (Tunnel2) is up: new adjacency
Sep  5 22:25:52 Summer: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 10.32.170.1 (Tunnel2) is down: Peer goodbye received
Sep  5 22:25:52 Summer: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 10.32.170.1 (Tunnel2) is up: new adjacency
Sep  5 22:53:14 Summer: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 10.32.170.1 (Tunnel2) is down: Peer goodbye received
Sep  5 22:53:14 Summer: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 10.32.170.1 (Tunnel2) is up: new adjacency
Sep  6 00:42:34 Summer: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 10.32.170.1 (Tunnel2) is down: Peer goodbye received
Sep  6 00:42:37 Summer: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 10.32.170.1 (Tunnel2) is up: new adjacency
Only one tunnel is flapping:
Spoke1#      sh ip eigrp nei
IP-EIGRP neighbors for process 100
H  Address                Interface      Hold Uptime  SRTT  RTO  Q  Seq
                                            (sec)        (ms)      Cnt Num
2  10.32.170.1            Tu2              13 00:06:22  182  1092  0  5500897
1  10.24.170.1            Tu1              11 2d10h    161  966  0  3706579
0  10.24.166.4            Et0              11 28w2d      2  200  0  8137
In the Hub US we have this log:
Sep 5 18:11:21 EDT: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=9079, sequence number=13538
Sep 5 18:12:58 EDT: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=9079, sequence number=13950
Sep 5 18:15:09 EDT: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
        connection id=9079, sequence number=14701
Can somebody give me an advise?
Let me know if you need more information
Everyone's tags (3)
1 REPLY
if you are using your spoke backup tunnel for redundancy only and no load sharing is required you can configure below and that should fix the issue for you.
To enable one tunnel interface to act as backup to other tunnel interface. You just specify the backup interface as second tunnel interface on primary interface and configure if-state nhrp on the primary tunnel interface. If that is done primary tunnel go down if registration with HUB fails and backup tunnel will come up
inter tu 1
if-state nhrp
backup interface tunnel2
inter tu2
if-state nhrp
863
