07-17-2014 06:41 AM - edited 03-04-2019 11:21 PM
I am currently labbing a DMVPN / EIGRP environment to replace our existing IPsec environment. Our core environment looks like this:
Core Router (2951)
Core Switch (3750)
Spoke Router (2911)
I've set-up the tunnel interface and EIGRP between the Core Router and Spoke and communication is no problem. The issue I am running into is the core switch houses the majority of our VLANS, so the spoke router can reach the core router, but not behind it to the switch.
The Core Router and Switch are connected by an access port with a separate EIGRP config.
Suggestions?
07-17-2014 08:17 AM
Hello
Have you tried redistributing between the eigrp processes or apply some static routes?
res
Paul
07-17-2014 08:43 AM
All works great if I add static routers on the hub.
I'm new to using EIGRP. How would I redistribute between the processes?
07-17-2014 08:52 AM
I simply added:
router eigrp 50
redistribute eigrp 11
All is working now. Is there any caveats I should be aware of?
07-18-2014 01:22 AM
Hello
Mutual redistribution can be quite difficult to manage especially when you have multiple exit points attached to different routing processes which can easily introduce loops in the network( something that we don't want to occur)
But these can be managed by Racls Tagging, metric manipulation etc. to the routes you are advertising/redistributing.
res
Paul
